Temp paint for rotors
Old 01-14-2013, 01:13 PM
bb69
bb69's Avatar
Default Temp paint for rotors
I'm looking for a paint/marker to determine how hot my rotors are getting. My car uses a dual master cylinder setup and I'm trying to make sure I'm using enough rear brake. Any advice on what you've had success with is appreciated.
Ken
Old 01-14-2013, 01:53 PM
JeremyGSU
JeremyGSU's Avatar
Not sure what the answer is but I think whatever you paint it with will eventually fade. My C5 Z had bright red calipers when I got it and after about 6 track days there were pretty much a faded red/black and I can't get the color back.
Old 01-14-2013, 02:00 PM
bb69
bb69's Avatar
I'm looking for the kind of paint that turns color at specific temps so I can see how hot the rears are getting in comparison to the fronts. I'm not painting the brakes for cosmetics. Sorry, if that wasn't clear.
Old 01-14-2013, 02:53 PM
rfn026
rfn026's Avatar
I've used several different brands. They all seem to work the same. I paint 3 rotor vanes. Each with a different color. I do it in the morning before my first session.
Last year I experimented with the the little temperature indicating strips on the calipers. I think I like them better. You just clean the face of the caliper and stick them on. Just like the calipers they're a one time deal. You'll need a new set every day.
The temperature readings from the calipers to the rotors will vary greatly (with the rotors much higher) but that's not a concern for you. You're looking for brake balance so either way should work.
Richard Newton
Facebook
Tech Blog
To Temp paint for rotors
Quick Reply: Temp paint for rotors
