Looking for road race wheels
I'm preparing a C4 for road racing this year and need some sources for road race wheels.
Rules limit us to the 17 by 9.5 size and my chassis is a 1987.
Anyone know where to get the late year size wheel with the early year offset?
Or does everyone use long studs and spacers?
Thanks, Jay
Thanks, Jay
Suckin' gas, haulin' ass.
I bought mine from DOCZ- 1st Rate Corvette Parts & Acc.
They have the 5-spoke ZR-1 style wheels in early offset. Great prices.
I use them on my track car with no issues.
I do know that the tires may have to be mounted from the backside, so keep that in mind if you get them and go to have tires mounted.
http://www.1stratecorvetteparts.com/...on_Wheels.html
2nd wheel from the bottom would probably be what you are looking for.
You want the 34mm offset not the 52mm
ZR-1 wheels will work also
Im going with longer studs next year . Just want a few more threads on the lugs .
Where are you racing ? DOT or race tire ?
Thanks for the help.
I race with Midwestern Council of Sports Car Clubs which run on tracks around Chicago, mostly Blackhawk, but we go to Road America and Autobahn as well.
I am prepping for ITGT which requires DOT tires. I've been happy with Hoosiers on my other DOT cars.
I use the zr1 17 x 11's all around on mine. I have bought several of these replicas used, some from forum sellers, you will just need to make sure you get the 34 mm offsets as most are going to be the late model offset as said above. Start watching here and craiglist and soon you too will have sevweral sets, beacuase you will need rains (4), practice set (4), race set (4) and maybe autocross set (4) ! And then you have to fibd where to store all those wheels and tires! Good luck and PM me if you need any advice on the build.
Pm me if you need some parts . You never know what I have laying around here .
Good quality racing rim at an affordable price, http://www.forgestar.com/v2/wheelsf14.php
All wheels break, including fancy forged.
People have been using rotary forged wheels for track use for a long time with good results.
People have also been using spin cast wheels on the track for a very long time with good results.
What is important is the load rating and design of the wheels. There is an SAE testing procedure that will give you an idea of whether the wheels are "safe" for your intended use. The better manufacturers will have this info available. I am not sure if any of the "safe" mfgs listed have submitted their wheels for testing.
Former Vendor
Once we are satisfied with the model, prototypes are cut and sent to Standard Testing Labs in Massillon, OH for physical testing. They are tested to the SAEJ328 standard, when that test is finished the load is increased and the test is repeated. This process is repeated until failure.
Not only do we test every wheel style, but every size in that style. We also test competitors wheels and the "safe" manufacturers consistently perform at very high levels - unlike others.
