LS1 front and rear cover alignment tips?
Old 12-04-2012, 12:57 PM
apexman
apexman's Avatar
Default LS1 front and rear cover alignment tips?
I am replacing the gaskets and seals on my LS1 motor in my 2000 FRC. Oil pan, front and rear seals etc. I was wondering if anyone had any tips to make sure everything is aligned properly without using the tools recommended in the factory manual?
Thanks,
Derek
Old 12-04-2012, 04:48 PM
apexman
apexman's Avatar
Surely some of you have replaced the front and rear main seal? I know all of you don't just throw in new motors when you get a leak Just looking for any helpful hints that will keep me from having to pull this again with a leak.
Old 12-04-2012, 05:22 PM
6SPEEDZ
6SPEEDZ's Avatar
The covers need to be level with the block. Most guys usually put liquid teflon on the joints after the covers are on but before the oil pan. The oil pan needs to be level with bellhousing flange.
Old 12-04-2012, 06:03 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I've never used any special tools, dab of sealant at joints as aboce
Old 12-04-2012, 06:09 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Use a flat to measure off the block. (I use the caliper's flat edge).
(Front) Then measure the distance between the flange edges to the crank.
Rear install with the old seal. Get the edges using a flat, tighten down cover. Pull out old seal, put in new seal. Done
Corners are important to put a small dab of sealant of some sort. We use Permatix Ultra black.
Randy
Old 12-04-2012, 08:20 PM
apexman
apexman's Avatar
Thanks for the replies guys. I figured I wouldn't need the tools as I never did doing just the front seal.
To LS1 front and rear cover alignment tips?
Quick Reply: LS1 front and rear cover alignment tips?
