keyless ignition?
Old 11-30-2012, 11:02 AM
redtopz
redtopz's Avatar
Default keyless ignition?
I seem to have lost my only key for my ST2 car after my last race. Does anyone know if a C5 can switch to an aftermarket ignition switch panel like this?
http://www.longacreracing.com/catalo...d=900&catid=12
Or will I need to get a new unit from GM? Thanks.
Old 11-30-2012, 11:07 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
PM sent
It can be done by it will be cheaper / easier to just have a new key(s) made.
Keep the spare in the trailer - that and an extra battery kill switch key is a good idea too!
Old 11-30-2012, 11:16 AM
redtopz
redtopz's Avatar
Originally Posted by 96CollectorSport
PM sent
Thanks, I'll try to do that.
Old 11-30-2012, 12:53 PM
brkntrxn
brkntrxn's Avatar
.... an extra battery kill switch key is a good idea too!
But that only affects Denny Hamlin at Martinsville.
Old 11-30-2012, 11:26 PM
fatbillybob
fatbillybob's Avatar
I think the way it works is that the key has this tablet thing and it communicates and unlocks the ECU so it can start. On 5.2+ motronics you can't separate this function or turn it off. But if we are lucky you can with a tuner just like the tuners fake out the CLB fuel cutoff by changing the parameter to 200mph or something like that. Maybe post in the C5 tune section?
To keyless ignition?
Quick Reply: keyless ignition?
