C5 Weight Reduction and Data Systems
With NASA nationals coming out West next year and the power to weight ratio dropping to 8.0:1, I need to get a little more serious about my car setup and cut some weight. My car is a 99 FRC with ACP aero kit and LS6 engine. It's heavy at 3250 lbs with driver even with carbon fiber hood, lexan glass, no headlights, and no wipers. Most of the weight I think is due to the robust cage and large dry sump reservoir in the passenger seat area:
The only things I can think of for removing weight are the dash and the roof B-pillar. I don't want to spend money on carbon fiber body parts. How much weight can I save by gutting these items?
Also, has anybody replaced their dash guages with an AIM MXL Pista in a C5? Thanks.
What about going ***** to the wall and eliminating the starter and move to super small battery. Push start it every time. Then think about how much weight the driver can loose? No offense... if your cage is good enough, start removing structure, gut those doors to the max, replace floor panels like behind driver seat with thin aluminum.
Then again you could prob just sell and move to an e30 and save yourself a lot of hassle. What are other guys running weight wise in a c5? Seems like i would want to get it down to 2800 bare min.
Bu im no c5 expert, but 3200 seems still a bit high.
Oh and get rid of the headlight reservoir... headlight fluid can be pretty heavy...
I would assume you've already got lightweight wheels...
Gutted doors
Remove AC condenser
Remove emergency brake stuff
Remove all un-needed interior pieces
Remove clutch and replace with lightweight clutch (Quartermaster)
Lightweight battery
Gutted doors
Remove AC condenser
Lightweight battery
You have to get real creative and make no compromises - everything that's not critical goes. I can't say for sure what mine weighs now, but I'd venture to say that there are only two C5's that I know of that are lighter than mine.
The Pista should be relatively easy to wire in (though you will need to pull the signal from the sensors, and some are 1 wire, so you will likely need a pull-up resistor - AIM should be able to help with this). The problem will be the gas tanks. I think you will need to build a summing circuit for the signals from the two senders. I would be curious what has been done for this as I have seen some cars w/o the OEM gauges.
That's the plan in addition to cutting weight.
Yes to all the above.
It was in the car when I bought it. I've never seen one like this before so I'm not sure if it's a custom setup. I think it's adding 50 lbs with the box and associated caging around it, but at least it's in a good location.
Do you still have the dash and stuff behind the dash? something doesn't seem to add up
I'm with Mark on this one... something doesn't seem right.
before VIR I passed the 2600 lb threshold with the carbon ACP hood. It's ~2595 or so. The low hanging fruit at this point is the driver
