starting car with no drivetrain?
Old 11-13-2012, 04:27 PM
bags142
bags142's Avatar
Default starting car with no drivetrain?
In process of changing clutch and 30 other parts...
Just did rear main seal, and I was curious if I connected the flywheel ONLY, could I start the car and check for leaking without having to put the all the drivetrain back on?
edit, I know I will get 1,000,000 codes, but will it hurt the engine? And I have the car supported properly and the engine has a dedicated jack stand under it.
bags
Old 11-13-2012, 04:50 PM
RX-Ben
RX-Ben's Avatar
It should be similar to running it on an engine dyno (before the load is applied) and not much different than idling with the clutch engaged.
But, you will need to make sure that everything is sturdy and the engine doesn't move into and crack your firewall upon startup.
Old 11-13-2012, 08:21 PM
Timz06
Timz06's Avatar
Yes, absolutely.
Old 11-14-2012, 06:40 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Shouldn't cause any problems. I've done it myself.
Old 11-14-2012, 08:39 AM
DOUG @ ECS
Premium Supporting Vendor
DOUG @ ECS's Avatar
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes on 656 Posts
Old 11-14-2012, 09:29 AM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
If your goal is to see if the rear main seal leaks why not rent a smoke machine - you don't need to start it and it will show a leak much better than running the engine.
Just a thought.
Old 11-14-2012, 10:54 AM
bags142
bags142's Avatar
Thanks everyone
Just a thought.
Hmm... now that is another option. Never thought about that...Thanks
To starting car with no drivetrain?
Quick Reply: starting car with no drivetrain?
