Nitto NT-01 C5 Z06
Old 11-12-2012, 03:05 PM
Sebring27
Sebring27's Avatar
Default Nitto NT-01 C5 Z06
I have a 2004 C5 Z06 that I am using as a track care at sebring.
I have fitted NT-01's on the car 315/30/18 the back and 275/40/17 on the front. I also have a newly fitted Wilwood kit Brake kit. The Active Handling/ ABS service light constantly appears which I have read about - could be the SS lines? However perhaps it could be the tires as the backs are now 30's and not 40's? Additionally any thoughts on how the 30's as opposed to the 40's will effect handling ?
If anyone has opinions, experience or knowledge it would be highly appreciated
Many thanks !
Old 11-12-2012, 04:40 PM
63Corvette
63Corvette's Avatar
IMO.....the rear tires must be about 0.5" larger in diameter than the front tires or you will get codes.
Old 11-12-2012, 05:01 PM
froggy47
froggy47's Avatar
research or measure the tire heights & post back.
Or run in comp mode or all nanny off.
Old 11-12-2012, 05:32 PM
Sebring27
Sebring27's Avatar
Back wheels now 24.75"
Front whesl now 24.5"
Also have Z16 !
Old 11-12-2012, 05:48 PM
froggy47
froggy47's Avatar
Also have Z16 !
I think that's the issue the sizes are too close. I would recommend just run comp mode or all nanny off & you'll be fine.
Old 11-12-2012, 07:32 PM
RDnomorecobra
RDnomorecobra's Avatar
interesting how some have a problem with that and some don't. I run a square setup with a 2003 z06 and have no lights/codes/etc.
Old 11-12-2012, 07:38 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,103 Likes on 717 Posts
18" square all around with no nannies and no problems - '03 Z.
Old 11-13-2012, 12:03 AM
sothpaw2
sothpaw2's Avatar
I ran that combo on track this year and drove to + from without codes or lights.
My car is a 2002. Maybe the newer car had a different PCM calibration??
Old 11-13-2012, 12:07 AM
froggy47
froggy47's Avatar
OP has an 04, GM messes with the algorithm from time to time yr to yr.
Old 11-13-2012, 01:07 AM
stevensa
stevensa's Avatar
FWIW my 02z has no issues with those exact tires in those sizes.
Old 11-13-2012, 06:17 AM
talon95
talon95's Avatar
I've run the 275/315 combo in Kumho MX's on my '03 without problems. Another local guy has that same size combo in the Azenis 615k's with no problems, his is an Z16 even.
Old 11-13-2012, 08:31 AM
lbk16
lbk16's Avatar
I run the same sizes (Toyo R888) on my 03Z with no issues.
Old 11-13-2012, 10:35 PM
johninar
johninar's Avatar
I'm on my third set of the exact same NT01 sizes without any issues or DIC messages.
Old 11-15-2012, 08:38 PM
Soloontario
Soloontario's Avatar
I ran 315s all round with my Z16 car. No problem with nannies on or off.
(Did have hub issues which triggered dreaded "service traction control...ABS light but fixed with new hub)
Your problem may not be the tire sizes.
Old 11-18-2012, 10:38 PM
theVcar
theVcar's Avatar
St. Jude Donor '08
The issue I believe starts with 2005. I have a post asking same question. Because I want slicks.
Old 11-20-2012, 10:46 PM
randomus
randomus's Avatar
I'm running the C5 Z06 wheels on my 2008 C6 with those NT-01 sizes and need to to into competition mode to drive without issues.
To Nitto NT-01 C5 Z06
Quick Reply: Nitto NT-01 C5 Z06
