Toyo R888 size recommendation
Old 11-11-2012, 01:07 PM
seebobgo
seebobgo's Avatar
Default Toyo R888 size recommendation
C5 Z06 for HPDE events and some street.
Rear 315/30/18
Fronts 275/35/18 or 285/30/18 or 295/30/18
Any other experiences welcome.
Thanks in advance
_Bob
Old 11-11-2012, 02:18 PM
RDnomorecobra
RDnomorecobra's Avatar
i've run their 305/35-18 at all 4 corners. I think they're too tall. probably cant go wrong with any of your choices there. could even run the 315/30's up front.
Old 11-11-2012, 03:37 PM
Last C5
Last C5's Avatar
I'm running 295/30/18s up front to clear the cooling ducts and 315/30/18s in back with the 888s. I've also ran the 295/30/18 Pirelli Trofeos all the way around with good results. (The 295 is the largest tire Pirelli makes in 18") Like the other poster said, you can't go wrong with a lot of those options.
To Toyo R888 size recommendation
Quick Reply: Toyo R888 size recommendation
