StopTech installation question
I am considering purchasing a set of Stoptech ST-60 /40 and I have a few installation questions. The instructions recommend trimming the lower ball joint (in some cases). Did you need to do that? Also, will these brakes fit with stock C6 Z06 wheels without shims?
Thanks for the help,
Charley
Charley
Had no problems with mine. Just make sure you insulate the ball joints. They get HOT. I run stock wheels with no problems. My race tires also are on stock wheels with no shims or problems.
Are you talking about the actual ball joint or the outer edge of the lower control arm where the ball joint sits?
I have a Brembo BBK and I had to grind down the outer edge of the lower control arm so the rotors wouldn't rub against the control arm. Didn't have to shave off much, you can use a grinding wheel or sanding disc, pretty easy to do.
Jay
Jay
Jay
Jay
Thanks, it is good to hear that it is easy to trim.
Charley
The thing that's the PITA is you have to assemble the wheel and lower the car to put weight on that corner and check for clearance. It will look like it will clear in the air but rub on the ground.
Jay
Jay
It is not a big deal! Just grind a little aluminum off the end of the lower control arm before you assemble them. When you put the disc on the hub, just look at where it would make contact if it were weighted and grind off in the area. There is plenty of material there. Also they will clear stock wheels. JD
Jay
Jay
It is stoptech SOP. When they designed the scca t1 kit on my c5 they trimmed as suggested with a simple sandpaper flapwheel. Very little was removed and in not a critical place. In fact the area is like a partline in the casting and the sanding even removes stressrisers in the metal there which is not a problem anyway of gm would have done it.
Charley
Received 3,805 Likes
"Ask Tadge" Producer
jas
Stoptech has redesigned the kit, so it is not necessary to grind the outer corner of the lower control anymore. I have experience with both kits, make sure you ask for the updated adapters/hats. The updated kit is great, enjoy the brakes...they work!
trophy series St40 per T1 rules. Extra 6 pot is good when you need to reduce pad taper. Well the T1 kit with st40's you get no taper so don't add the weight or extra parts to rebuild later by adding the 6 pot. 2 years racing still same rotors! On 3rd set of front pads never worn out the rears. The T1 kit is more brake than the car needs. I only bleed brakes as part of my pretech. I don't need to bleed during the the race weekend. I'm just using cheapo valvoline synthetic brake fluid too. With OEM's I cracked the front rotors on the 3rd day and pads were gone in a weekend.
