A/C belt comes off at track?
So I am at RA and lift the hood on my third session only to find that the a/c belt has jumped off AND is not broken, plus my main serpentine belt has lost its outside (front) rib but is still on correctly. Riddle me this....how does the a/c belt jump off without breaking and the main belt tears but is still in place?
How old are the belts ? Have you carefully checked the pulley alignment and tensioner condition. Check the harmonic balancer for separation and wobble. Have never heard of an AC belt coming off before. I once had a main serpentine belt that would walk itself off the pulleys 2 ribs during a run session. Checked alignment of all pulleys and everything was fine. Replaced the belt and it has not happened again.
CI 3-5-6-7-8 Veteran
Check to make sure you crank pulley isn't coming loose or starting to fail and wobble excessively. All the OEM ones wobble a little so don't expect it to be 100% true.
