FS: Sparco Seats, Sparco 6pt Harnesses, VetteWorks HArness Bar C6Z
Old 09-05-2012, 02:20 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
Default FS: Sparco Seats, Sparco 6pt Harnesses, VetteWorks HArness Bar C6Z
Looking to sell the following setup:
Seats/Brackets and Harness (--SOLD--)
Sparco Rev seat (dated 1998)
-condition is fair, material is weathered on left hand side (facing sun) but no rips or tears. Still functions fine.
Sparco EVO2
-basically new, dated 2008 i believe. Its barely used and you can tell just looking at it.
Both seats are attached to Pfadt seat brackets. One is a slider, the other is fixed.
Sparco 6pt Harness ( -- SOLD--)
-attach to the seat brackets for the lower 4 belts and the upper two go to a roll bar.
-camlock design
-one harness is current to Nov 2012, other i believe just expired.
-Both in fantastic shape.
Looking for $1200 + s/h for the above setup.
VetteWorks Harness Bar (SOLD)
-Comes with both side mount brackets and all hardware (plus extra hardware.
-Also have the pre-drilled sail panels for C6Z such that you won't need to drill into your factory panels. Have all spare tabs in case you break yours as well as new push pins.
Old 09-05-2012, 09:21 PM
blacklsx
blacklsx's Avatar
Is the offer for 2 sparco evo 2 seats?
Old 09-05-2012, 09:35 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
No, it's a Evo2 seat and Rev. They look somewhat the same but are not.
Old 09-05-2012, 09:39 PM
JDIllon
JDIllon's Avatar
Very confusing? the pictures only show one Sparco seat and one harness, and then some pictures show stock seats and Harness bar. But the copy says 2 seats and 2 harnesses and 2 mounting brackets and Hdwe. Also are the seats mounted with side brackets or bolted thru the bottom? Clarify please and more pictures of how everything mounts up if possible. Thanks JD
Old 09-20-2012, 02:30 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
Bump
To JD, sorry for not getting back to you, never even saw the response.
i only had one sparco installed in the car at the time of photo. There are two seats, as pictured now. I remove the sparcos for street use, as they are not comfy for me.
the seats do mount with side brackets, you can kinda see it in the first pic.
Aj
Old 09-20-2012, 10:24 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
harness bar is sold
Old 09-27-2012, 03:09 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
bump...
Rev seat is sold (but i removed brackets from it). so if anyone is interested in both seat brackets and harnesses, $1000 for all of it.
Aj
Old 10-13-2012, 11:37 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
Bump. Need to sell remaining items left. Evo2 seat, both harnesses, both seat brackets.
Old 10-14-2012, 01:19 PM
hungryhippo
hungryhippo's Avatar
How much?
Old 10-23-2012, 12:58 PM
braknl8
braknl8's Avatar
I need one bracket and a method to mount lap/sub belts, if still available?
thanks,
Old 10-23-2012, 05:13 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
Originally Posted by hungryhippo
How much?
first post says it. 1000 for all i have left.
thanks,
i don't want to split up the pair since everything matches. if i had a buyer for one of each, i'll split. i might have a buddy interested in one seat bracket, if he comes thru, will pm you on the other.
Aj
Old 10-23-2012, 06:08 PM
braknl8
braknl8's Avatar
Aj
10-4, let me know.
thanks,
Chris
Old 10-27-2012, 11:48 AM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
Seat brackets/mounts and harnesses now sold.
EVO2 seat is left. $500+ s/h
- no seat brackets... It's just the bare seat
Old 11-04-2012, 02:37 PM
1 BAD BURB
1 BAD BURB's Avatar
St. Jude Donor '06
bump
Old 11-04-2012, 02:39 PM
Z06ness03
Z06ness03's Avatar
Ohhh noooo i wish i had seen this sooner... bummer.
To FS: Sparco Seats, Sparco 6pt Harnesses, VetteWorks HArness Bar C6Z
Quick Reply: FS: Sparco Seats, Sparco 6pt Harnesses, VetteWorks HArness Bar C6Z
