2006 Bri-Mar 16ft open trailer for sale $1650
Great condition, just repainted. Located in Southern NJ. Please ignore the messy backyard, I have to throw away the plastic tarps. I also have a SUPERWINCH GP5000 that I will throw in the deal at no extra cost. It comes with the mounting plate and just slides right into a custom hitch in front of the deck. It has all the connectors and remote. This is one of the lightest weight steel trailers out there at only 1660lbs. Great for good gas mileage and improved towing for smaller tow vehicles.
ONE ISSUE - One of the ramps fell out when I was towing as I did not secure it properly one day and it got bent up. It still works 100%, BUT it no longer fits into the bottom slide because of the bends. I have to put it inside my tow vehicle. The other slides in fine. You can buy a new one, but for me it was not big deal to throw it inside my truck.
SPECS:
Worry free loading and unloading is now available with the Car Trailer. No more damage to lower profile front ends or after market effects with this new low load angle trailer. The removable fenders make it easy to open doors after it is fully loaded.
♦ GVWR: 7,000 lbs.
♦ Bed Length: 16’
♦ Width: 82” Inside / 102” Overall
♦ Deck Height: 20" (16" at Rear)
♦ Empty Weight: 1,660 lbs.
______________________________________
•4" Channel Main Frame
•Diamond Plate Decking
•5' Dovetail
•5' Slide-Out Ramps
•Removable Fenders
•Stake Pockets (6)
•D-Rings: (6)
•2-5/16" Ball Coupler
•BullDog 5k Top Wind Jack
•7 Way RV Plug
•Breakaway Kit w/ Push-To-Test Battery
•Sealed Wiring Harness
•LED Rubber Mounted Lights
•ALKO Ultra Lube Axles
•Electric Brakes on Both Axles
•Tires: ST205 / 75D15
•PPG Powder Coat Finish
•Color: Black
Additional Options
Options
•Spare Tire and Wheel
•Spare Mounting Kit
•Winch Plate (weld-on)
SPECS:
♦ GVWR: 7,000 lbs.
♦ Bed Length: 16’
•5' Dovetail
•5' Slide-Out Ramps
•Removable Fenders
•Stake Pockets (6)
•D-Rings: (6)
•7 Way RV Plug
•Color: Black
Additional Options
Options
•Spare Mounting Kit
Trailer
Do you still have the trailer? Thanks
PLEASE RETURN MY EMAILS....VERY INTERESTED IN THE TRAILER.
No response
Forum members that post items for sale and do not respond to inquires or questions within 24 hours should be banned from inputting any posts for a six month period. In addition, these idiots should have their membership privileges suspended for 90 days.
Uh... this initial post was 2 years ago...
My bad
You got me there....forgive my stupid, BUT administrators should remove and or have threats taken down WAY sooner than two years.......besides stupid, someone is also asleep at the wheel!
