Newbie here
Oldtimer
Newbie here
Hi all, I'm a newbie to this part of the forum, and did my first autoX at Carlisle list week. I've now been bitten by the bug and want to learn as much as I can. I have a couple if initial questions .
When does one pull the trigger on buying a helmet, and what to buy? I tried to do some research but I can't get any definitive answers. I see reference to motorcycle helmets as being "good enough" , then other recommendations to use automotive specific helmets. I don't know what the standards are as well.
Secondly I understand one must use special brake fluid. Where does one get It and where to have it installed?
Thanks for now!
Thanks for now!
NC Events Coordinator
If you intend to do HPDE or racing you'll need a Snell-rated helmet SA-2005 or SA-2010. They're only good for 10 years so a 2005 would expire in 2015. I got the Bell Sport SA 2010.
I'm sure you'll get lots of opinions on brake fluid. I have Motul RBF600 in my car now.
Welcome to the fun!
Get a SA rated helmet. You may get away with a motorcycle helmet at AX but very few car clubs would allow one on a track. You can buy online (OG Racing, Racers Warehouse, etc) or find a shop in your area to try on. New Jersey Motorsports Park in Millville has a "pro" shop that carries helmets and most other things you might need (fluid for example). Call ahead to make sure they are open however (they only open when there is some event at the track).
You'll want a DOT 4 rated brake fluid. Buy online is usually best way as it can be hard to find at a local shop. There are many, many brands. Motul RBF600 and ATE Superblue are two popular fluids. I get Motul thru Amazon. As far as changing the fluid - best to learn to do it yourself because its something you will do frequently if you really get into this sport.
I've also got a Bell Sport SA 2010, and it's a great choice. And DOT 4 fluid and brake pads (Carbotech, for example) are essential if you are going to track your car.
If you're just interested in autocross, though, your stock brakes and fluid are just fine.
Jim
Jim
Ahhhhhhh - you are hooked!!! Just don't blame me!!!
I agree w/ the above advice for Snell"SA" rated helmets. Although the events run under NCCC rules will allow helmets w/Snell "M" (motorcycle) rating, other groups may require "SA" rating - which tests the impacts more related to car impacts and roll bars - it also requires fire proofing. The SA rating will ensure that you can move to high speed/HPDE, driving schools, or participate at events run by other groups.
I'm not sure that you would need DOT 4 brake fluid for AX, especially as a beginner, but . . .
Lots of great info on this forum and a great place to get answers and advice. Check the 'sticky' on AX and road racing above.
Find a good race store and try different makes, models, and sizes - make sure it fits properly and is comfortable !!
Good luck,
Mike
Good luck,
Mike
Are you wanting to do other driving events ie. HPDEs or just autox? If you're just doing autox then you might want a less expensive helmet than if you were going to do an HPDE. It depends on how much you like your head.
You want fresh clean brake fluid you do not need a high dollar fluid at this point in your driving career.
Welcome to your new addiction.
Oldtimer
I agree w/ the above advice for Snell"SA" rated helmets. Although the events run under NCCC rules will allow helmets w/Snell "M" (motorcycle) rating, other groups may require "SA" rating - which tests the impacts more related to car impacts and roll bars - it also requires fire proofing. The SA rating will ensure that you can move to high speed/HPDE, driving schools, or participate at events run by other groups..
Good luck,
Mike
Good luck,
Mike
I'll pm you some info on our club's event at Pocono North course - not confirmed yet, but will be April or late May (Memorial day weekend.
