Corvette 06-12 ZO6 Track Pack Stage II Performance Brake Package
Former Vendor
St. Jude Donor '13
This is a great package for those who want/need to step up to better brake package yet still don't need the all out race package. If you are just starting to do some Autocross, HPDE, High Speed driving or are ready to move up a step in your performance here is a great entry to mid level package
Package Includes:
(1) Set Stop Tech Corvette C6/ZO6 Stainless Steel Rear Brake Line Kit
(1) Set Stop Tech Corvette C6/ZO6/GS Stainless Steel Front Brake Line Kit
(1) Set Hawk HP Plus Street Front Brake Pads 1 pcs design
(1) Set Hawk HP Plus Street Rear Brake Pads 1 pcs design
(4) Pints Motul RB600 High Temp Race Brake Fluid
(2) StopTech Front Gas Slotted Rotors
(2) StopTech Rear Gas Slotted Rotors
Motul RBF600 is the best high-temperature Brake Fluid and preferred by many tuners and race teams. Its specifications and labratory results exceed that of DOT 5 silcone based fluid, but still retains the benefits of Glycol based fluid by lubricating the ABS pump and not deteriorating caliper and Master cylinder seals
100% Synthetic Brake and Clutch fluid. Compatible with all Dot 3 and 4 fluids. Specifically designed to resist the high temperatures of actuated (steel or carbon) racing brakes and clutch systems.
StopTech® braided stainless steel brake line sets provide quicker, firmer, more consistent pedal response. Additionally, stainless steel lines provide precision brake modulation, especially during threshold braking. The improvement in pedal feel is more dramatic on older vehicles where the factory rubber line may have softened and swelled due to age. Each StopTech® stainless steel brake line kit consists of the replacement hoses, as well as the brackets and fasteners required to service one axle. To ensure a trouble-free installation, StopTech® recommends that you thoroughly bleed the brake system after installing the hoses, and check the routing of the hoses to ensure that they are free from binding, kinking or interference with other components.
Hawk HP Plus utilizes a unique Ferro-Carbon, high-tech friction material that was developed and manufactured for sport driving in autocross, Solo II and track day applications. The Ferro-Carbon formulation offers lower wear rates and higher torque values than other competitive materials.Extremely high coefficient of friction makes HP Plus the perfect upgrade over stock for high performance streetcars used in autocross competition or that experience repetitive, heavy braking.
* Extremely High Friction Output
* Fade Resistant
* Worthy for Autocross & Club Racing Events
* Fade Resistant
StopTech Power Slot® rotors are 1-piece, slotted, direct replacement discs for your factory brake system and stock calipers. They offer improved cooling as well as other advantages the competition doesn't offer. Slotting helps wipe away the debris that forms between the pad and the disc, adds more bite, and can help the rear brakes to match the aesthetics of a front big brake kit. The rotor finish helps prevent glazing of the
pads and improves wet and dry braking performance. Additionally, StopTech Power Slot® rotors feature a durable black e-coating on the non-swept areas of the rotor to prevent corrosion.
$985.55
delivered lower US
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
http://www.xplosiveperformance.com/0...ge_p_3171.html
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
* Fade Resistant
Price just reduced additional savings from our suppliers past on to you
$955.55
delivered lower US
$955.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Former Vendor
St. Jude Donor '13
Package Includes:
* Fade Resistant
$985.55
delivered lower US
Package Includes:
* Fade Resistant
$985.55
delivered lower US
