FS Pace 28 Enclosed Car Hauler
Trailer was purchased brand new in 2010. 2009 Pace Pursuit Monza package 28 foot enclosed car hauler/trailer. This trailer is fully loaded and equipped just like a Shadow GT, but with a different cabinet configuration.
-Dual 5200lbs axles (GVWR of 10,000lbs - dry weight ~4500lbs)
- Screw-less exterior and interior walls
- Dual fluorescent interior lights with 12v lights too
- Dual quartz exterior lights on entry door side of trailer
- Rubber coin flooring with Aluminum tread plate
- Carpet on walls to add a more finished look and feel
- Ample cabinet storage
- Tie down area to store roll on tool chest
- 48" entry door
- 15,000 BTU A/C (COLD!) with heat pump (not heat strip). The AC keeps the trailer ice cold in 100+days and the heat pump will keep the inside high 70s-80 degrees in under 30 degree outside temps.
- 50 AMP shore power with extra length shore power cord and 30A to 50A connector
- Interior and exterior electrical plugs
- 10,000lb Equal-i-zer weight distribution and sway control hitch included!
- Misc items included (ez tire changer, spare wheel and tire, locks)
Many other options - the build sheet for this trailer is over 2 pages long in just options. The trailer is lightly used and only towed between Charlotte, NC and VIR and CMP racetracks. Total mileage on trailer is less than 3,000 miles.
Asking $14,750
- 48" entry door
Asking $14,750
PM sent
