Minimum Tread Before Weekend?
Old 05-14-2012, 12:28 AM
Bad Karma
Bad Karma's Avatar
Default Minimum Tread Before Weekend?
Memorial Day weekend I have an HPDE & High Speed Autocross. I'm running Michelin Pilot Sport PS2's the rears have about 1/32" above the wear indicator. Do you guys think that's enough to survive the weekend? I'll replace them before if I have to but would be nice to run them down before buying a new pair.
Old 05-14-2012, 04:57 AM
stevensa
stevensa's Avatar
1/32" above the wear indicator, so 3/32" left total? If so that should be fine.
Old 05-14-2012, 07:00 AM
AU N EGL
AU N EGL's Avatar
That is PERFECT.
just above the wear bars is perfect for a track event.
Old 05-14-2012, 11:35 AM
Bad Karma
Bad Karma's Avatar
Thanks guys. Just wanted to make sure I would have enough tread left for both days, because I know I won't be able to replace them on a Sunday or Memorial Day itself.
To Minimum Tread Before Weekend?
Quick Reply: Minimum Tread Before Weekend?
