Will aC6 PS cooler fit a C5 Z06
Old 03-19-2012, 03:03 PM
bsalie99
bsalie99's Avatar
Default Will aC6 PS cooler fit a C5 Z06
I wanted to know if anyone has installed the C6 Power steering cooler on a C5 Z06. I have a leak in my current OEM C5 cooler and grabbed a like new one from a junkyard, but it came off of a C6, The bends in the hard lines are a bit different. I wanted to see if anyone knew if they would fit a C5 before took the system apart and found out the hardway.
Quick Reply: Will aC6 PS cooler fit a C5 Z06
