CCW C-14 Race Wheels
Navigator
I have 3 sets of CCW Single Piece forged 6061-T6 Aluminum CNC Machined Wheels for Sale. They WILL ONLY FIT A C6!!!! 2005 to current model year. They are in MINT condition. They all have A6 or R6 tires mounted on them. I will sell them with or without tires. The fronts are 10 in rims and the rear are 11in rims. AGAIN THEY WILL NOT FIT A Z06! Call Tom with any questions (cell- 770-309-2276) That is the fastest way to reach me. The rims are located near Atlanta, Ga. Asking $1800 without tires or $2300 with tires. Tires only have one or two max test sessions on them. The wheels are 18X10 in front & 18X11 rear.
/Users/Kelly/Pictures/iPhoto Library/Modified/2012/Feb 28, 2012/IMG_2927.jpg
/Users/Kelly/Pictures/iPhoto Library/Modified/2012/Feb 28, 2012/IMG_2928.JPG
/Users/Kelly/Pictures/iPhoto Library/Modified/2012/Feb 28, 2012/IMG_2930.JPG
/Users/Kelly/Pictures/iPhoto Library/Modified/2012/Feb 28, 2012/IMG_2931.JPG
Location: If you don't weigh in you don't wrestle Road America
You could use them with a C5 if you have CCW make you some spacers. The fronts will mount up fine it's the rears that would need a spacer. Stock C6 rear wheels have a 79mm offset and a C5Z rear has a 56mm offset so depending on how much offset John at CCW built into the wheels you would need up to a 1" spacer. Call John at CCW and he will tell you what you need. I believe spacers are around $125 per axle. Hope this helps.
Navigator
What is it that causes them to not work with the Z06? Is it the brake size? CCW advertises them to fit the big brake packages. I was looking at getting a set for my car but if they won't fit the Z06 brakes, then I guess I will have to find something else.
I have ONLY 2 sets left of C-14 CCW Single Piece forged 6061-T6 Aluminum CNC Machined Wheels for Sale. They WILL ONLY FIT A C6!!!! 2005 to current model year. They are in MINT condition. They all have R6 tires mounted on them. I will sell them with or without tires. The fronts are 10 in rims and the rear are 11in rims. AGAIN THEY WILL NOT FIT A Z06! Call Tom with any questions (cell- 770-309-2276) That is the fastest way to reach me. The rims are located near Atlanta, Ga. Asking $1800 without tires or $2300 with tires. Buyer pays all shipping costs. Tires only have one or two max test sessions on them. The wheels are 18X10 in front & 18X11 rear.
/Users/Kelly/Pictures/iPhoto Library/Modified/2012/Feb 28, 2012/IMG_2931.JPG[/QUOTE]
