wtb body control module c6
hey guys looking for a good used body control module
it seem like mine took a dump.. maybe something happen during the process of welding the cage in..who know..
Manny
305-333-4445
Mannysanchez360@gmail.com
Manny
305-333-4445
Manny
305-333-4445
Manny
305-333-4445
Also '05 is different than '06 - '09
Might check to be sure the kill switch issue didn't smoke it before you invest in a replacement.
I also think (not sure) that it will have to be programmed by a dealer ... not just with a tech tool.
You cannot use an old BCM from another car, you have to use a brand new one if you want all the functionality to be maintained..i.e. theft deterrent, air bags etc. However, if this is a dedicated track car and you don't car about the air bags and theft and radio, it will work just fine.
I ran into this issue with my 06Z. I had to swap out the BCMs and bought a used one but couldn't get the air bags to self check. Turns out the BCM is VIN locked. I had to buy a new one, install it and have the dealer use a TechII to flash it. Everything worked fine after then.
Jay
Jay
