5w-40 Mobil 1 diesel for track only?
Old 03-09-2012, 12:19 AM
thatonedude1
thatonedude1's Avatar
Default 5w-40 Mobil 1 diesel for track only?
Anyone ever try using 5-40 for the track only to counter the effects of viscosity loss for oil above 260 - 270 degF?
Old 03-09-2012, 01:01 AM
rustyguns
rustyguns's Avatar
40 weight will work to around 270. i hit 290 so i use 20/50
Old 03-09-2012, 01:46 AM
db2xpert
db2xpert's Avatar
You need a better oil cooler.
Old 03-09-2012, 05:58 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
you have different additives in diesel oil. Go to bobstheoilguy.com
To 5w-40 Mobil 1 diesel for track only?
Quick Reply: 5w-40 Mobil 1 diesel for track only?
