FS: Penske 8200 LE coil overs
I have a set of used Penske 8200 LE coil overs for sale. These are valved for street and track use.
This is a track-tested setup that ran 1:20.6 at Streets of Willow on a stock C6 Z06.
Here's the writeup on the shocks from Gary at hardbar:
The Penske 8200 LE is a brand new shock system that uses all of the superb first class Penske 8700 3 way shock with a new internal separator piston to provide a low cost option. Hardbar and Leading Edge worked with Penske to offer this exclusive option. Now you can have the very best and upgrade as your needs and budget permit. This is an upgradeable system that has the capability of being easily converted to the 8300 2 speed or 8700 3 speed at a later time, by removing the separator piston and adding the hoses and canisters. All of the internal parts, and all of the best in class Hardbar mounts including the 17-4 PH "T" bar, the upper clevis mounts, and the adjustable rear lower clevis (shown in red anodized finish) are the same as the 8700 series. This shock has the best spring adjuster available on Acme threads as well. These are priced each and springs are optional as well. Suitable for leaf or coil-over applications. These are $550 each plus springs (if desired). As with all Hardbar products, they are 100% made in USA and each one is individually dyno'ed and you get the data files.
Price for complete kit including 4 coil overs Penske shocks, dual-rate hypercoil springs, dyno charts, and all hardware = $1,695.
*** Also available are additional spring rates/configurations. Please inquire if interested.
Can you define used? How many miles, track days, etc? How old are they? Can you post pics or send them to me? Also you say available with other springs. You have multiple sets of springs? Please provide more details.
I have an additional set of springs (Eibach) which I can sell separately with the Penske/hardbar kit. It's simply offered as an option since the packaged hypercoil springs work great as well (talk to Gary at hardbar or Richard at Leading Edge for the engineering details behind their kit). I will sell the additional spring set for $200.
First come, first serve.
