Adjustable End Links For C5 And C6 For sale.
Old 02-29-2012, 05:04 PM
jfaphoenix32
Supporting Vendor
jfaphoenix32's Avatar
Default Adjustable End Links For C5 And C6 For sale.
We have just finished testing a new style of adjustable endlink that eliminates the noise of the heim joint styles.
These Power grid units install with out preload and provide ease of adjustament also.
Available in sets of 2 for 159.99, plus shipping and handling
Call 610-482-0141 or jfaphoenix32@aol.com...
Old 03-01-2012, 03:20 AM
db2xpert
db2xpert's Avatar
picture?
Old 03-01-2012, 06:41 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
are they Metric like OEM, or 1/2"? Are they short enough to be used in conjunction with OEM units?
Old 03-01-2012, 06:55 AM
jfaphoenix32
Supporting Vendor
Theyare metric and can be used with stock oem units. I willpost pictures as soon as the next units come in. First inventory has all been sold.
Old 03-01-2012, 07:49 AM
el es tu
el es tu's Avatar
Old 03-01-2012, 09:32 AM
waddisme
waddisme's Avatar
Seems like when I was researching end links, Powers Grid's were the mac daddy of end links.
Old 03-01-2012, 09:52 AM
drivinhard
drivinhard's Avatar
I have used them for awhile on my T1 bars, they are pricy but they have held up well and are quiet and very easy to set up.
Downside...at their shortest length they are still longer than OEM so you can't go budget and use OEM on one side.
Old 03-01-2012, 12:28 PM
MYRX
MYRX's Avatar
I agree. I installed mine on all 4 corners last summer. Makes adjustments very easy.
Old 03-03-2012, 12:15 AM
sperkins
sperkins's Avatar
I've found that to be true on every adjustable end link I've ever tried.
Also - I have no data to back this up, but I "think" longer than stock endlinks effectively softens the rate of the bar since it rotates it to a more upward position and thus having less leverage. Obviously a mm in overall length here or there isn't gonna matter, but it makes me wonder if extending the links to their max may actually make a difference.
Old 03-04-2012, 07:55 AM
davidfarmer
the further the angle goes from 90deg (longer or short) the stiffer you get.
I've used some heims with OEM, but you have to shorten the heim to get it short enough to match the OEM fixed unit. I don't remember which heims I used, but just had to shave a bit off of the threaded end.
Old 03-04-2012, 08:12 AM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
I have them and they are a great product
Old 03-05-2012, 06:30 AM
jfaphoenix32
Supporting Vendor
pm sent
Old 03-05-2012, 02:30 PM
el es tu
el es tu's Avatar
can you give specs on the movement?
Old 03-08-2012, 06:10 AM
jfaphoenix32
Supporting Vendor
pm sent. Will check on specs
To Adjustable End Links For C5 And C6 For sale.
Quick Reply: Adjustable End Links For C5 And C6 For sale.
