I'm installing my own alignment shop in my garage
OK, I've had it with my local alignment shop. They can't put my car on their rack without damaging the front splitter, and they want to charge my $85 to align a car that only needs a toe adjustment for one wheel. I'm done with paying for alignments, and working around the shop's schedule. So I bought this: http://www.bbxracing.com/
It looks awesome, I can't wait to get my hands on it and do my own alignments. Anyone have any experience with this setup? I got an extra set of adapter plates so I can use it to align my Z06 and my F1000 car.
I have seen those before and been intrigued. I thought about getting them. Now I will just borrow yours. ;-)
Oli
Oli
I have not yet used those, but have known of similar setups well before they were made commercially available. You still need to use a level surface and you also need to run parallel strings at hub center height with car at ride height to use correctly. What those do is replace the wheel and allow a whole lot more access to make the job easier. To set the toe properly you need to measure at what would be the tire radius (at hub centerline). Mitler has a similar product:
http://www.mittlerbros.com/index.php...nt-system.html
Well I admit I was a bit on the fence at first about whether it was worth the investment, but now I'm sure it will be a good decision. It solves all my alignment problems that I've been having with the vette, and any problems I would have had aligning the F-car. Just think:
I can align my car on the night before a track day
My alignment shop is never closed or busy
My alignment shop really cares about getting the job done right
No more worrying about my cars being "too low"
No more paying for alignments, especially small jobs and tweaks
That would be sweet, but a tire changer and balancer looks really expensive...
Don't forget to buy a tire changer while you are at it.
Received 8,928 Likes
Bill
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Those certainly look cool! Waaaay out of my price range though. I do my alignments with home made angle toe plates, a level and a square.
Pro Mechanic
I saw those a while ago & thought there was no way for suspension to settle with out setting them on turtables. I see now they are rubber mounted & allowed to lean & pivot. Very Cool. I made 4 3ft. tall tables with screw in feet. I laser leveled & mark floor. I set turn plates & scales on them. Put car on hoist & set down on slip plates on tables. The scary part is rolling from slip plates to scales. They are very cumbersome for 1 guy. It does end up very accurate. Would be way easier to buy the hub stands. I don't see how guys can do home alignment adjustments without. If you lift the car up to adjust now what unsettled & start over.
I use 4mil garbage bags folded in 1/4's on top of each scale. No rolling on and off required. You would be amazed at how slippery they are. I left the car on them one time when a friend came over. We were drinking a beer or three while talking and I was leaning against the car and it slid off the scales. sideways
Limitations . . .
Every system (Did I say EVERY SYSTEM?) has its limitations. The beauty of what you are doing is exactly what you mention: You are doing it, your way, and to your specs. Just don't be afraid to fill in the blanks with the steps that method does not do well enough.
Ed
Ed
It can be used later for its intended use, just get the grit out of it.
I do the exact same thing during alignment adjustments using my 4-post lift. I actually get very nervous that the car is going to slide off the lift, hit one of the center support beams and knock the whole house down.
