Special deal on Ferodo Racing brake fluid!
Old 02-08-2012, 11:50 AM
JRitt@essex
Supporting Vendor
JRitt@essex's Avatar
Default Special deal on Ferodo Racing brake fluid!
Hi Guys,
We’ve recently started importing and selling Ferodo’s latest line of brake fluid, Ferodo Super Formula DOT 4 Racing Brake Fluid. It’s one of the most versatile brake fluids on the market today, and is perfect for everything from daily driving to endurance racing...in your clutch or brake system. We’ve had a number of customers run this fluid on the street and track over the winter with excellent results.
We want to get the word out about this new product, so for limited time we’re running a special deal: Buy 2, Get 1 free! This offer is only valid for retail customers, not wholesalers (shops). Each customer may only use the coupon one time. Also, the maximum quantity this discount can be applied to is 1 case (24 bottles…you buy 16 and get 8 free).
To take advantage of this deal, you must purchase through our website and use the coupon code, “freeferodo”. Please note that you must enter the total quantity of fluid you will be receiving, including the freebies. For example, if you’re buying six bottles, you’ll get three free. When adding the fluid to your cart, you must add all nine bottles before checkout for the discount to be properly applied. If you’re buying two and getting one free, you need to add all three to the cart, then enter the coupon code.
We believe those who’ve been using some of the more common fluids on the market will be very pleased with their results when they make the switch to Ferodo Super Formula. If you’re a member on other automotive forums, please post a note about this deal, share it with your friends on Facebook, Twitter, etc. Again, this deal is only going to run for a limited time, so get ‘em while the gettin’s good! Thanks for your consideration gents.
Old 02-17-2012, 07:56 AM
JRitt@essex
Supporting Vendor
Sale is still valid on the fluid...thanks for the orders guys.
Quick Reply: Special deal on Ferodo Racing brake fluid!
