This is what happens when you get bored on a Sunday............
Old 02-06-2012, 11:23 AM
geerookie
geerookie's Avatar
Default This is what happens when you get bored on a Sunday............
So this past Sunday I was bored and decided to work on my winter project. 8 1/2 hours later this is what I ended up with. The car is MUCH lighter than Mark's now
Some of my winter projects will include:
Relocating the ABS pump and EBCM inside the car to get the weight off the nose
Relocate the PCM etc. to inside the car
Flip the Rad forward
Install a QuarterMaster 7.25 8-leg Optimum-V clutch
Install 243 heads, 25% Underdrive ATI Damper, LS3 water pump and set Rev Limit to 6800rpm
Install ZR1 Spindle Uprights to reduce caliper mount flex
Relocate alternator
Install all new brake lines
Make front splitter removable to ease loading on the trailer
If my calculations are close I should have 50%/50% front to rear static and 51%/49% side to side weight distribution with no ballast and be at about 2955lbs with me in the car and 1/2 tank of gas when I'm done. This also includes a passenger seat.
Here's a picture of the ABS and PCM relocate. I haven't finished cleaning up the wiring yet but when I shortened all the wiring harnesses I removed about 6lbs.
I weighed my SPEC Clutch which has a special aluminum lightened pressure plate and a Fidanza aluminum flywheel, it was 31.5lbs. The new Quartermaster setup is supposed to be about 15lbs.
With all the work to relocate stuff and remove any extra weight I have pulled about another 55lbs off the nose of the car.
And some of the weight I had to keep up there I moved to the passenger side of the car.
Old 02-06-2012, 11:43 AM
2MCHPWR
2MCHPWR's Avatar
impressive!
no headers this year?
Old 02-06-2012, 11:44 AM
GCMan
GCMan's Avatar
My miata project needs that motor if you are not needing it....
Old 02-06-2012, 11:45 AM
geerookie
geerookie's Avatar
Originally Posted by 2MCHPWR
impressive!
Didn't need the extra power or headaches of working around them.
Used the money saved to pay for the clutch.
Old 02-06-2012, 11:48 AM
geerookie
geerookie's Avatar
You probably don't want it. It has 115k+ miles and about 35k are on the race track.
I'm just swapping heads, cam, lifters, springs, injectors, oil pump, timing chain and water pump.
Old 02-06-2012, 11:55 AM
AU N EGL
AU N EGL's Avatar
Nice drilled underside of the hood
Old 02-06-2012, 11:57 AM
travisnd
travisnd's Avatar
Looks like you got mighty happy with a hole saw on that hood! Impressive stuff as always. What really makes me chuckle is that you're just now starting your "winter" projects when the SE guys are racing at CMP this weekend and us MA folks are at VIR next weekend
Old 02-06-2012, 11:59 AM
geerookie
geerookie's Avatar
Thanks. I was itching for 2 days after that. The price you pay to save 2lbs and spend no money
Old 02-06-2012, 12:03 PM
geerookie
geerookie's Avatar
I'm about a month behind schedule. The "Home" projects which had to be finished before I dove into this (in order to not get into too much trouble) took longer than expected
Our first event is a DE at Limerock at the end of March which I may use as a shakedown but more than likely will not be ready until the Friday test & tune April 20th which is out first race weekend.
Old 02-06-2012, 12:06 PM
Short-Throw
Support Corvetteforum!
Short-Throw's Avatar
Cool, keep us updated!
Now would be a good time to add some reinforcement bars to your cage in the engine bay.
Old 02-06-2012, 12:34 PM
Falcon
Falcon's Avatar
Holy Smoke! G, you are one impressive guy! I think you'd tackle about anything!
Old 02-06-2012, 12:57 PM
geerookie
geerookie's Avatar
Thanks.
I can't paint to save my life. I really like what you did with the front end of your car.
Old 02-06-2012, 01:04 PM
geerookie
geerookie's Avatar
I wish you guys were closer. I could have used some help. I did all of that by myself with a floor jack
The wife did come out and hold the nose of the car up high enough for me to roll the motor and suspension out from under the frame on the floor jack. It took awhile to find the right spot so everything would balance properly.
Old 02-06-2012, 01:50 PM
Brent Dalton
Brent Dalton's Avatar
Looks like you were busy. All kinds of good mods. I just picked up the 7.25 8 leg as well. I can't wait to try it out.
Old 02-06-2012, 02:00 PM
geerookie
geerookie's Avatar
Did you get the Tri-Lite bearing and the LS Button flywheel?
Old 02-06-2012, 02:13 PM
RAFTRACER
RAFTRACER's Avatar
Yes, yes, he did.........
Old 02-06-2012, 02:29 PM
Brent Dalton
^What Danny said
Clutch ****(since we have the same clutch):
To This is what happens when you get bored on a Sunday............
Old 02-06-2012, 02:50 PM
geerookie
geerookie's Avatar
I will have some of that tomorrow as soon as the Brown truck arrives!
Did you buy it from Danny? QuarterMaster direct? Other?
Nevermind....I didn't see Danny's response...
Old 02-06-2012, 02:52 PM
Brent Dalton
The man from Cincinnati. That's what Quartermaster recommended I do. Just like all the other stories floating around here, Danny took the time out of his day to go over the various clutch options based off what I using it for. Once I decided, he got it to me quick, fast, and in a hurry.
Old 02-06-2012, 02:54 PM
geerookie
geerookie's Avatar
Still waiting on a price for the button flywheel
And this year my car should sound a little "meaner"
I think I'm going to get rid of the TI exhaust.
Quick Reply: This is what happens when you get bored on a Sunday............
