Anyone scuff wheel beads prior to tire install?
Old 02-01-2012, 09:12 AM
travisnd
travisnd's Avatar
Default Anyone scuff wheel beads prior to tire install?
I seem to remember some racers doing this to help minimize the tire moving on the wheel. I'm trying a new setup this season using C6 Grand Sport front wheels all around. They're comp grey and glossy all over. Figured I'd hit the bead areas with a scotch-brite pad before taking them to my tire guy. Good practice or waste of elbow grease?
Old 02-01-2012, 09:17 AM
sperkins
sperkins's Avatar
I'll use steel wool around the bead of the wheel if there's rubber and other crap stuck to it. Mainly though to help with air leaks.
Old 02-01-2012, 09:30 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I recently bead blasted a wheel. I'll let you know if it does better at CMP
CodeBlack
CodeBlack's Avatar
I spoke to Hoosier about the same thing. They also said to scuffs the time. Good luck
Old 02-01-2012, 09:40 AM
travisnd
travisnd's Avatar
Old 02-01-2012, 09:58 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Originally Posted by travisnd
damnyouautocorrect
Old 02-01-2012, 10:42 AM
CodeBlack
CodeBlack's Avatar
What was I thinking when I wrote that. Scuff the wheel. I had a mental break down
Old 02-01-2012, 10:44 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,387 Likes on 742 Posts
Same here except I use a plastic scraper rather than steel wool. Don't want to embed any steel particles in aluminum wheels that I don't have to.
HTH, and have a good one,
Mike
Old 02-01-2012, 12:08 PM
RX-Ben
RX-Ben's Avatar
One shop I went to used some spray glue to lock the bead in place.
With the prior low hp setup, I had zero issues one way or the other.
Old 02-01-2012, 12:30 PM
brkntrxn
brkntrxn's Avatar
After I documented my tires moving up to 180* on the wheel, I had my tire guy start using less lube when they mount tires for me. I have wanted to clean the beads for a long time, but my normal mode is to drop off the wheels/tires one weekend and pick them up the next.
In the research I did last year, scuffing the bead helps.
-Kevin
travisnd
travisnd's Avatar
I marked one set of tires last year and 3 of them moved maybe 1/4". The LR moved like 7". The only reason I brought it up is because these wheels are glossy even on the barrel and beads vs. most wheels that don't have shiney paint in those areas.
Old 02-01-2012, 01:52 PM
brkntrxn
brkntrxn's Avatar
Could be the difference in where we tested. I did my testing at CMP with a set of sticker As on the Z06 wheels. After one session, the fronts had moved almost 90* rotation under braking and the rears had moved almost 180* under acceleration. Meaning, the fronts and rears rotated in opposite directions. They moved a bit more after the second session and then did not move again for the weekend.
In talking to my tire guy at Discount and reading around the internet, the group-think is that the tires move in the beginning due to two factors: 1) lube in the bead and 2) jarring them when the tires are still cold. The first factor can be reduced by dry-mounting the tires or at least using less lube. The second can be reduced by warming up the tires before stomping on the brakes or nailing the throttle. Which, btw, heating the tires also helps evaporate the moisture in the bead lube.
In either case, I feel pretty strongly about scuffing the beads and keeping them clean. But seeing how much my tires move, that is also why I feel balancing a track tire is not all that important.
-Kevin
Old 02-01-2012, 02:07 PM
travisnd
travisnd's Avatar
Yeah... the one time I didn't balance my tires was my last time out at RA in December. Had a horrible vibration... never again. If you walk around the pits at any pro race you'll see they all balance them.
If it works for you great... but It didn't work for me
Old 02-01-2012, 02:15 PM
el es tu
el es tu's Avatar
why not media blast?
might also want to google for images of the nissan gtr rims. I believe the term they use is knurled bead, but I bet there are other names for it...
Old 02-01-2012, 11:05 PM
trackboss
trackboss's Avatar
When I was racing the solution was to balance the wheels without the tires. Then simply check wheel balance every time the tires were replaced.
Old 02-02-2012, 02:31 AM
Last C5
Last C5's Avatar
You guys are making waaaaaaay too much work out of this.
My 888s used to move 4" in a day on my CCWs until I started mounting them with hairspray as tire mount lube. Go ahead laugh, but it works great for lube and the tire will stay where you put them till they cord. Now that's on a track car, not a drag car.
Yes, I use the extra hold variety. Seriously, it works perfectly.
Old 02-02-2012, 09:42 AM
travisnd
travisnd's Avatar
I'd be the laughing stock of the tire shop if I showd up with a can of hair spray
To Anyone scuff wheel beads prior to tire install?
Old 02-02-2012, 09:43 AM
CGZO6
CGZO6's Avatar
Maybe we can get Aquanet as a sponsor.
Old 02-02-2012, 01:18 PM
victorf
victorf's Avatar
FWIW, that is the standard for installing hand grips on motorcycle. After sprayed the id, easy slide on, wait overnight and its good to go. You will have to cut it off when you want to remove it later.
Old 02-02-2012, 06:24 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Quick Reply: Anyone scuff wheel beads prior to tire install?
