Tie Rod End Dust Boots
Old 01-29-2012, 10:18 AM
MartyZ51
MartyZ51's Avatar
Default Tie Rod End Dust Boots
Can anyone give me a specific part number and vendor for the dust boots that go over the tie rod ends on the front of C6? I've searched the forum and need more specifics. Energy Suspension sells them based on measurements and not for specific applications.
I want to have them in hand before I take the front suspension apart so I don't have to wait to put it back together.
Old 01-29-2012, 12:05 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
I have been told these work, cannot verify from personal experience
ENS-9-13101G
http://store.summitracing.com/partde...0&autoview=sku
Old 01-29-2012, 05:32 PM
MartyZ51
MartyZ51's Avatar
What could be wrong with $4. I'll post up if they work. Thanks for the info!
Old 01-30-2012, 06:04 AM
fred_S
fred_S's Avatar
I can tell out of experience that these fit perfectly, they will burn on the track though.
http://www.summitracing.com/parts/ENS-9-13127G/
Fred
Old 01-30-2012, 11:30 AM
travisnd
travisnd's Avatar
Fred
Just wrap them with DEI cool tape... they'll never burn again. I just got done swapping out my stock balljoint boots for these this weekend. Never used the tie-rod end piece, but I don't see why they wouldn't work. Been putting the cool tape on the lower balljoints and tie-rod ends of every vette I've ever tracked. Never had a burnt one. What's interesting is that the tape reflects enough heat to the point the zip-ties never melt or degrade. I don't bother covering the uppers anymore as the spindle acts as a sufficient heat shield. The tape is adhesive, but the zip tie is just in-case it comes unstuck.
Front
Rear
Energy suspension upper balljoint boot in place...
Old 02-01-2012, 09:14 PM
MartyZ51
MartyZ51's Avatar
Do you know which Energy Suspension item number it was for your ball joint dust boots? I messed up the lower one on my 2008 C6. They only have universal and not model specific.
Old 02-02-2012, 10:17 AM
fred_S
fred_S's Avatar
Front
Rear
I'm going to order some DEI cooltape, we will see if they hold up to my abuse, thanks for the tip.
Old 02-02-2012, 10:33 AM
travisnd
travisnd's Avatar
It will... my car is a track only race car. Been using it for years.
To Tie Rod End Dust Boots
Quick Reply: Tie Rod End Dust Boots
