C5: Bolting the h-pipe to OEM manifolds... A better way?
Old 01-08-2012, 10:31 AM
travisnd
travisnd's Avatar
Default C5: Bolting the h-pipe to OEM manifolds... A better way?
One of you guys posted a cheap/easy way to bolt the OEM H-pipe to the OEM manifolds using regular bolts/nuts but I can't find the thread or remember exactly how. The OEM bolt that threads into the manifolds never come apart w/o being unusable for me.
Can anyone post a picture for me or describe what you do? I can't remember if you thread a bolt down through the hole in the manifold from the top side thereby creating a new stud and then use a washer/nut to secure the H-pipe slip flange thing. Or, do you just use the right size/thread bolt and slip that through the H-pipe flange and thread it into the manifold from the bottom side?
Thanks!
PS - Tired of Paying $6 each for the OEM bolts and having to order them
EDIT: See post 16 if you want to stop buying $6 GM studs an $2 nuts for the manifolds.
Old 01-08-2012, 04:45 PM
RX-Ben
RX-Ben's Avatar
You will need some type of stud setup. I would thread stainless bolts in place of the existing studs. But you will still want a locking bolt there b/c of the temp swings.
What happens to your existing bolts?
And when are you testing the 245s?
Old 01-08-2012, 07:25 PM
travisnd
travisnd's Avatar
No matter what I do the nuts always cross-thread and the studs begin to bend when taking the H-pipes off. Maybe I'm over-tightening them when installing.
Running TTA and instructing at VIR in February. Took the H-pipe out to delete the cats.
Old 01-09-2012, 05:06 PM
joenationwide
joenationwide's Avatar
huh, interesting. I've dropped the H-pipe like 3 times now just trying to get to the CKP sensor. Luckily even with surface rust the nuts spun off like butter. One of the studs was already snapped, fortunately I could just barely get all the threads to engage on the nut.
A few times I had to hammer the ends of the studs towards the center of the collector. They were so flared out, it was impossible to get the flanges on/off.
Old 01-09-2012, 05:31 PM
RX-Ben
RX-Ben's Avatar
How are you guys lowering the exhaust?
If you have a pump jack under the H pipe, it seems like it would be hard to bend things as you can slowly lower it to make sure nothing is catching/twisting.
Old 01-09-2012, 06:32 PM
sperkins
sperkins's Avatar
Ben - he's saying that the studs bend from the torque of the socket when loosening (I think). I've had that happen before. On Greg's (northern) car, I had to replace 3 studs the first time I dropped the mid-pipe. Luckily, I had some OEM manifolds laying around the shop so I just snatched some from there.
If they look bad before I touch them, I'll usually take pictures (for the car owner in case I have to bill them), spray 'em down good, wire brush the crap out of them and hope for the best. I'll replace the nuts too.
Old 01-09-2012, 08:07 PM
brkntrxn
brkntrxn's Avatar
Committed to 245s and nothing else this year?
Old 01-09-2012, 08:15 PM
RX-Ben
RX-Ben's Avatar
Originally Posted by brkntrxn
Committed to being a test mule for various TTA setups and nothing else this year?
Fixed.
brkntrxn
brkntrxn's Avatar
I guess I got lucky when I dropped my mid-pipe last week. No issues even though they were rusty. I was worried, but they came off and went on just fine.
Ben,
I drop exhausts the redneck way. Place a hand on each leg of the midpipe at the header and place a leg under the rear part of the midpipe towards the tranny. Do the same to reinstall. Works great and is pretty cheap.
-Kevin
Old 01-09-2012, 09:38 PM
travisnd
travisnd's Avatar
I use my floor jack and a a board to support the pipe. The studs aren't bending from that, they're bending from removing the nut... no matter what I do the thread get boogered up and the nut gets stuck 1/2 way off.
I already stole all the good ones out of my spare manifolds before I scrapped them so I'm ready to go to a cheaper option than OEM. One of the T1 racer guys posted up awhile back about how they do it using regular bolts.
As for the 245s... if the 245s don't work I'm just going to have a 1/2 assed ST2 car. I do have a spare H-pipe in my shed if I had to use it.
Old 01-09-2012, 09:45 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
As for the 245s... if the 245s don't work I'm just going to have a 1/2 assed STR2 car.
fixed
Old 01-09-2012, 09:46 PM
travisnd
travisnd's Avatar
Greg did post on NASA forums that they reviewing the "hole in the frame" rule.
Old 01-10-2012, 07:37 AM
SoDiezl350
SoDiezl350's Avatar
It's quite possible. IIRC the torque require for those nuts is quite low(something like 15 ft-lbs)
Old 01-10-2012, 07:48 AM
travisnd
travisnd's Avatar
If that's the case then I'm way overdoing it.
Old 01-10-2012, 10:02 AM
SoDiezl350
SoDiezl350's Avatar
Just checked online and that is the recommended torque.
Old 01-15-2012, 05:36 PM
travisnd
travisnd's Avatar
No more GM studs... used some 10x1.50 coarse threaded bolts with a lock washer under the head of each. Threaded them up into the manifold
Old 01-15-2012, 08:07 PM
PushinTheLimit
PushinTheLimit's Avatar
Brian... if you want to get sell your mid-pipe, I'll be in the market for one in a few weeks. I've already got a TI exhaust on the way to getting closer to PTA.
Old 01-15-2012, 08:48 PM
travisnd
travisnd's Avatar
It's the original from my 2001 so it has four cats vs. two; you probably want one from a 2002-2004.
To C5: Bolting the h-pipe to OEM manifolds... A better way?
Quick Reply: C5: Bolting the h-pipe to OEM manifolds... A better way?
