Corbeau FX1 pro question
Old 12-31-2011, 08:50 AM
2 GTOs
2 GTOs's Avatar
St. Jude Donor '11-'12
Default Corbeau FX1 pro question
I have a cobra seat on a hard bar fixed seat bracket on the driver side of my C5. I would like to add something to the passenger side as economically as possible to allow me to take a coach.
If I use a corbeau fx1 pro on the passenger side with the corbeau slider ( I already have one). Will I have any issues sitting in the seat with a helmet for a 5' 10' person?
Where is the point where headroom becomes a problem for this set up?
Old 12-31-2011, 08:54 AM
2 GTOs
2 GTOs's Avatar
Default Seat thread size
Also, does anyone know the thread size for the stock seat studs coming up from the floor used to mount the seats to the car. I need to buy new nuts. Grade 8 I assume?
Old 01-01-2012, 03:37 AM
Last C5
Last C5's Avatar
I have that set up and I'm 5' 10" - no problem what's so ever. BUT, if your coach has more than a 38" waist he won't fit in the FX1 Pro. What I run is the Pro for myself on the driver's side and a standard FX1 on the passenger side. Both seats are on Corbeau sliders.
Old 01-01-2012, 09:17 AM
JeremyGSU
JeremyGSU's Avatar
I have Corbeau FX1's on both sides on the Corbeau sliders and I'm 6'1 1/2 and have no problem fitting in the car.
However, I don't recommend the Corbeau sliders. I'm getting ready to get rid of mine. They don't recline the seats enough IMO and make it uncomfortable to drive around in. I even tried the shave method and they sit too upright IMO.
Old 01-01-2012, 11:09 AM
2 GTOs
2 GTOs's Avatar
No fitment problem with the regular FX1? I was under the impression people had trouble getting them to fit.
Old 01-01-2012, 03:29 PM
Last C5
Last C5's Avatar
If mounted directly to the slider the FX1 will rub (just barely) the upper door trim. If you stick an 1/8" spacer between each of the two outboard seat mounting bolt holes and the slider the seat fits just fine.
You can't tell the difference looking at the seat after the install.
Old 01-01-2012, 09:29 PM
67Ranger
67Ranger's Avatar
The studs are M10x1.5
Old 01-01-2012, 11:03 PM
MX621
MX621's Avatar
im looking into the fx1 as well.. im 6'3 and i have just enough headroom with a helmet on stock seats in my c5z.. does the fx1 with the mounts have the same amount of head room?
Old 01-02-2012, 02:12 AM
Last C5
Last C5's Avatar
My track pardner is 6'3" or better and he's ridden with me in the FX1 seat many times and seems to clear OK.
Old 01-02-2012, 07:40 PM
Joy of 6
Joy of 6's Avatar
that's me he is talking about and I fit just fine
Old 04-02-2012, 10:52 AM
SuzukiDan7
SuzukiDan7's Avatar
How the heck did you fit at 6'3"? Im 6'2" and do not fit.
I don't know if its my mount / slider, but I have an FX1 in my '02 z06 with what I think is the corbeau slider and I barely fit with no helmet. With a helmet I do not fit and have to slouch down into an uncomfortable position to be able to keep my head from hitting.
I am currently exploring options to lower the seat, whether its getting a reclining seat like the a4 or possibly a new slider mount, maybe shaving the base / remounting the seat somehow, I don't know yet.
Old 04-02-2012, 02:52 PM
Last C5
Last C5's Avatar
My Z is an 01 and somewhere in there they changed the headliner. That may be the difference.
Old 04-09-2012, 11:17 PM
Bluefire
Bluefire's Avatar
I will spare everyone the painful install iterations I have been through with my FX1 Pros. I'm 5'11". I must be "long bodied" because I couldn't fit with a helment on either. I ended up going with the Arizen sliders. Those allowed me to tilt the seat back slightly (which helps) and I need to cut&sand off the rear mounting posts on the seat. Now my helmet clears with a little more than 1" of headroom.
Old 04-10-2012, 08:43 AM
argonaut
argonaut's Avatar
I'm 6'0 and use FX1 Pros on sliders and I don't fit with helmet on. I remove the seat cushions on track. This year I'm installing the hardbar rails to side mount the seat and move it down a little.
Old 04-10-2012, 09:22 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
I am 5' 11 1/2" and I barely fit with helmet. I have FX1 Pro with Corbeau slider. I have the FX1 on the passenger side with custom rails that are offset by 1/2 in so no rubbing. It is not on a slider and because I switch stock seats back for dd, seat is farther forward than I would like just so I can reach rear bolts. Yaw sensor makes it hard to do anything else without moving sensor.
Old 04-10-2012, 11:39 AM
Charley Hoyt
Charley Hoyt's Avatar
I have a similar, but slightly different set up. I am using a Cobra seat with Arisen sliders and I have plenty of head room....Of course it helps not having a roof
Old 04-10-2012, 01:04 PM
2 GTOs
2 GTOs's Avatar
I ended up with the cobra Suzuka and hardbar rails on the driver side and I used the fx1pro with corbeau slider on passenger side. I look for the shortest instructor because there is little headroom on the passenger side.
There is very little comparison between my driver and passenger set ups. I really like the cobra on the hardbar rails
Thanks for all the help.
To Corbeau FX1 pro question
Old 05-13-2012, 11:02 AM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
With the sliders IMO you get less headroom than with the stock seats when lowered down all the way. I have my FX1 mounted with the side rails. Obviously it is fixed in place, but at 6' 5" I have plenty of headroom and more leg room than if it was on sliders.
Funny thing is that the FX1 Pro says it only fits up to a 36" waist, but I have a larger waist and fit no problem!
Old 05-13-2012, 11:38 AM
TriplBlk
TriplBlk's Avatar
I find this rather funny, I was gonna make a comment about finding the skinniest instructor, that way, he'll fit in your seat AND keep the total weight of the vehicle down
Old 11-06-2013, 09:23 PM
JeremiahsC5
JeremiahsC5's Avatar
Good info. Going to install the fx1, 38" and 6'-1" tall.
Quick Reply: Corbeau FX1 pro question
