Retain or Remove the Lower Air Dam with a Splitter?
Old 12-29-2011, 10:27 PM
Gman57
Gman57's Avatar
Default Retain or Remove the Lower Air Dam with a Splitter?
With all the current threads on areo and with just adding a rear wing on my car the questions coming up for me are.......
* Will the APR front air dam (like the ZR1 design or Ktech) be enough or do I add to it by making a custom splitter?
*Attach it under the APR air dam and extend it out 2" creating a air splitter and full undertray. By doing this I would be removing the OE rubber flapper/air dam. I have looked over several older threads with conflicting pros/cons removing the OE air dam.
*What would be the best way to reroute the brake ducting? Would I still get enough air to the brakes if I cut out the opening in the new under tray at the factory location with out the OE rubber air dam?
Thanks for your input
Old 12-29-2011, 11:30 PM
Git Er Dun
Git Er Dun's Avatar
How big of a rear wing are you adding? That really dictates how much front downforce you need to generate and what kind of a setup you need to run...
Old 12-30-2011, 07:30 AM
AU N EGL
AU N EGL's Avatar
Does the air flow up into the radiator?
Old 12-30-2011, 09:36 AM
Gman57
Gman57's Avatar
70" APR- GTC 500
No... This is a Z06 C6 front breather
Old 12-30-2011, 03:53 PM
jlutherva
jlutherva's Avatar
With the Katech ZR-1 splitter, you can get the brake ducts that connect from the OEM ducts to the front openings on the splitter. This provides significantly more air flow to the rotors (assuming you also have a Quantum Cooling kit or equivalent). My rotor temps dropped substantially when I added the Katech splitter.
Is the splitter enough to balance a rear wing. Gee, I doubt it! I believe it was designed and tested to work with the Katech full spoiler, not a wing.
In addition to balance, you also are going to have to figure out reinforcements that are well in excess of the ZR-1 fiberglass reinforcement. There's a thread somewhere that discusses this. The problem is that in hot temps, the entire fascia can be deformed downward.
Should be a fun project!
Jim
Old 12-30-2011, 04:44 PM
Gman57
Gman57's Avatar
Jim
This is what I was thinking too......
I will have a much more support from the front other than the fascia it self.
Old 12-30-2011, 05:45 PM
Painrace
Support Corvetteforum!
Painrace's Avatar
The C6Z air dam is to provide a little air to the brake ducts in stock form. It also adds a lot of front end lift. Take it off and throw it away but you must get more air to the brakes. The Katech unit is what I have with the undertray and brake ducts. You also need back plates to run the hoses to the inside of the rotors.
If you move the Katech undertray forward 2" you will get a ton more front down force but the front facia support is not enough to to keep the front of the car up. You are going to have to add additional supports to the frame.
Aero balancing a car is not easy. Best of luck to you.
Jim
Old 12-30-2011, 08:55 PM
Gman57
Gman57's Avatar
Jim
This is along the line of what I wanted to do. I need to find out if the Ktech ducting will work for me since my splitter/air dam is the APR and not the Ktech splitter.
Option 2 would be to go the fog light route for ducting.
I think if I can get the front aero close I should be able to adjust the rear with AOA of the wing.
Anyone use 1/8" aluminum to fab the undertray? About $600 less than CF. A bit more weight would be the trade off.
Old 12-30-2011, 09:17 PM
Falcon
Falcon's Avatar
Try Alumalite. Stiffer than a 10th grader's unit after looking through Hustler magazine and very light. Cheap, too.
Old 12-30-2011, 10:07 PM
Gman57
Gman57's Avatar
Good idea
Old 12-30-2011, 10:17 PM
Falcon
Falcon's Avatar
Good idea
A few of us use that as an undertray. Call a local sign shop, they usually have it.
Old 12-30-2011, 11:22 PM
Gman57
Gman57's Avatar
Yep.... you were reading my mind, one of my customers has a sign shop and they do all my graphics! Are you using the 6mm-1/4" stuff?
Old 12-30-2011, 11:24 PM
Gman57
Gman57's Avatar
What do you do if anything to finish the outside edge?
Old 12-31-2011, 10:41 AM
Falcon
Falcon's Avatar
I (and I suspect most who have this type undertray) are using the 10mm size.
Some splitters you get will have a lip wide enough to cover the exposed edge of the undertray. In other words, the undertray will be cut to fit into the splitter.
If it doesn't completely cover it, you can use any silicone sealant to dress up the edges. That would be for cosmetic purposes only, the Alumalite will not separate.
Old 01-01-2012, 03:11 PM
Gman57
Gman57's Avatar
From the posts made, emails and phone conversations is why this forum rocks......
Old 01-01-2012, 04:56 PM
PushinTheLimit
PushinTheLimit's Avatar
This sounds like something I need to look into on my aero setup.
Old 01-02-2012, 08:11 AM
JDIllon
JDIllon's Avatar
Hey Gary, good luck with the project! Let us know what you decide. JD
Old 01-02-2012, 02:48 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
http://www.mcmaster.com/#rubber-molding/=fmtulu
To Retain or Remove the Lower Air Dam with a Splitter?
Quick Reply: Retain or Remove the Lower Air Dam with a Splitter?
