trailer hitch
trailer hitch
Searched high and low but could not find any info.
I have a 2007 Z51 equipped,does any on make a
hitch to fit. Curt Mfg. says it will not and I learned the hard way
hitch hits sway bar hard. Thanks for any info
Bill
Bill
I have an 05 Z51 coupe. Friend modified the Curt hitch to fit around Borla Stingers. Uses same 4 mounting points. Close fit to sway bar, but no problems. Pulled a 4' Harbor Freight trailer (5 track tires +tools) to VIR, Mid Ohio and Putnam this season. Ran like a champ with no issues. Curt hitch doesn't work with the NPP OEM exhaust.
sway bar by 1/4 to 1/2 inch
sure fits my NPP (dual mode exhaust)
Picture can be seen by going to :
http://s1111.photobucket.com/albums/...with%20hithch/
I encourage others to do the same.
To OP -- If you use the Curt plug and play wiring harness, the instructions that came with it are incorrect for grounding. I used the flat silver grounding strap that runs along the outside of the rear bulkhead as a ground. Works fine
Thanks again 72Vega haven't got that far yet but will do
