Trans oil cooler - plumbing, filter?
Took a really quick look but don't have time to mock up before I make sure I have everything needed - I see there is a T fitting included - are there 2 scavenge lines or 2 feeds?
Has anyone used an in-line filter on the scavenge side? Seems like a good idea. Looking to use a "coarse" one (filters down to .050") since the 149 micron ones seem like they will clog regularly (pain to replace the screen). Any thoughts?
Thanks.
Thanks.
Location: If you don't weigh in you don't wrestle Road America
I've used these on several cars in the past and have never found them to get clogged up.
http://www.summitracing.com/parts/EAR-230306ERL/
Let's put it this way if it's clogged, you've got bigger issues.
I put them in line to help try to save the pump if something does go wrong.
It's just a screen, you could probably go to a hardware store and find a more coarse screen if you felt the one that came with it was too restrictive.
Filter saved our pump. Gasket material used in a rebuild clogged the filter.......was doing a fluid change and used the pump to cycle the old out........barely got a trickle.......pulled the filter and it was PACKED with rubber chunks.
Always use a filter.............
