FS: 2008 Corvette LS3 - T1/STO/ST2
I'm selling my white LS3 Vette. $65K
* Phoenix built 2008 Corvette LS3 with less than 1K miles on the engine.
* Beautiful, clean white car with matching cage and interior.
* ARE 3-stage dry sump with multiple coolers.
* 3-time SEDIV T1 champion
* Tranny, diff and Cool-shirt cooler.
* 3-way Penske adjustable shocks
* DL1 data system with OBDII port and display
* 3 sets of CCW 18” wheels and tires (including rains)
* 14" rotors with Z06/GS front brakes
* spares include 2-piece lightweight rotors (F and R), calipers, brakes, hubs, etc.
* Rear of car recently converted to Grand Sport specs
* Serious inquiries only please.
Chris Ingle
678.378.3259
wtknght1@aol.com
Chris Ingle
678.378.3259
wtknght1@aol.com
The LS3 is stock, but with the ARE dry sump. I'll post some pictures this weekend when I get some time. Here are some vids of the car in action though...over the past 3 years...against cars that should be much faster.
http://www.youtube.com/watch?v=FxM6MWjyp68
http://www.youtube.com/watch?v=vHRrdU3eAtI
http://www.youtube.com/watch?v=tUyBN...eature=related
I put the wider fenders on there, kicked the rear tires out 3", added the side air scoops (brake coolers), and also added the different 3d brake light (that has a bit of a lip to it) to give it more downforce. That also means I could run the wider wheels (13") and tires (345s) if I wanted to. You'd have to add 50 lbs to the car though if you decided to do that.
Plus, the wider fenders definitely look !!!!
OK guys, as requested, here are some cage and interior shots of the car. The overhead view shows the beautiful work Phoenix did on the cage. I've since moved the cooler to the pass side, but the cage work is still the same. You can also see the 3-way Penske shocks mounted to the long cage rails.
Also in these shots, you can see the NASCAR style side door beams...nice and low which makes entry and exit easier. In the center of the dash, you'll see the DL1 display and below that are all the cool-shirt controls, tranny and diff coolers, etc. Everything is labeled, incredibly well laid out and easy to reach.
The album of shots is here:
http://forums.corvetteforum.com/album.php?albumid=18320
http://forums.corvetteforum.com/pict...ictureid=97618
http://forums.corvetteforum.com/pict...ictureid=97620
http://forums.corvetteforum.com/pict...ictureid=97621
http://forums.corvetteforum.com/pict...ictureid=97622
http://forums.corvetteforum.com/pict...ictureid=97619
