Do you need coil overs with a wing?
Old 10-24-2011, 04:10 PM
Wild Horzes
Wild Horzes's Avatar
Default Do you need coil overs with a wing?
Thinking of putting a wing and 4 inch front splitter on my C5. T1 suspension right now. Planning the cage install next month and was wondering if I heard correctly that the monoleaf doesn't like a bunch of down force. True, false? Anybody running a wing and splitter with a T1 kit?
Thanks!
Gary
Old 10-24-2011, 05:12 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
false leafs will work too. You need the right ones like anything else.
Old 10-24-2011, 06:05 PM
TRACKMAN2
TRACKMAN2's Avatar
run a splitter and wing on the c4 lots of downforce...you can even see it in the tire wear temps. cross springs no problem.. i cant imagine it would hurt the c5 i think it would benefit greatly from one...it would keep the suspention closer to its "sweet spot" the most important thing to remember when doing airo is its not brain surgury!!! shure you can beat your self up trying to get the perfect ballance of downforce and drag...just hold your hand out the window at 50 hold it flat...now angle the front down it will dive down more than back....just go by results not what anybody tells you...your lap times will tell what works its trail and error.....if i had a buck for every time i heard that cant or dosent work i got fed up and said your right it dosent!!!!!
Old 10-24-2011, 10:49 PM
trackboss
trackboss's Avatar
Coilover is the most misunderstood word I've ever seen used.
Old 10-25-2011, 12:15 AM
Gary2KC5
Gary2KC5's Avatar
I can only comment on 1 race track that has some decent high speed straights and one real downforce corner...the carousel at Road America.
my buddies Z06 has a big rear wing, cam, and headers. My Z06 does not and I can pull him(drafting) down the straights and follow him nose to tail in the carousel.
I think the big wings look cool but I can't say they offer much performance advantage...if now a performance negative for speed
Old 10-25-2011, 12:20 AM
RacePro Engineering
RacePro Engineering's Avatar
Isn't that what they use in the Seely Posturepedic?
Old 10-25-2011, 03:08 AM
trackboss
trackboss's Avatar
Ha, maybe that's why I'm on leaf springs during the day and tempurpedic at night.
Old 10-25-2011, 04:17 AM
John Shiels
Is that why most if not all race cars have wings that are allowed to?
Old 10-25-2011, 07:46 AM
PushinTheLimit
PushinTheLimit's Avatar
Just ask the guys that can run under 2 mins at VIR in ST2 cars that have aero... it works. Using the T1 suspension will work with aero, but its not optimal. I had considered going with a wing and splitter this year since my car already has the T1 suspension, but I've decided to hold off till I can get stiffer springs and revalve my shocks before I put the aero on.
Old 10-25-2011, 08:01 AM
Wild Horzes
Old 10-25-2011, 08:04 AM
Wild Horzes
Thanks for the thoughts!
Gary
Old 10-25-2011, 10:38 AM
RacePro Engineering
I think the big wings look cool but I can't say they offer much performance advantage...if now (sic) a performance negative for speed
Gary2KC5,
Your comparison here does bring up a good point that Gary N. should consider before investing in aero pieces, and possibly stiffer suspension, and possibly ________ , and possibly ________.
As GoldenEagle states, it is obvious that aero improves the performance of our cars. What may not be so obvious when one is starting down this path, is the amount of knowledge, time, and money required for development. To your point, simply bolting a big wing on the rear of a car virtually ALWAYS makes it go SLOWER.
So, one must decide if looks are the goal, or is it actual speed.
When racing, like with any of the other components on the car, aero devices need to be integrated into the package, and their trade-offs completely understood. This typically requires extensive "testing" - a poison word for most on this forum.
I suppose the point is, if one is to go fast, be prepared for a long journey.
Ed
Old 10-25-2011, 12:46 PM
Wasserott
Wasserott's Avatar
Default T1 with Aero you Describe
Been there and done that exact same thing.
T1 (shock/springs) will bottom out the front end on braking and will rub in the rear upon exit. I ran it as several tracks before i said enough. It was plenty fast and grippy and I didn't feel unsafe with it, just couldn't handle the extreme ends...going deep and coming out fast!
I'm running the LG C/O setup now. I think about 700lb front and 600 rear. Those rates i would say are a minimum.
As for leaf springs, Danny Popp runs leafs just fine! I believe he runs something like 900 or 1000 lb springs. They are crazy stiff but he likes that.
Old 10-25-2011, 03:48 PM
RX-Ben
RX-Ben's Avatar
What rubbed on corner exit?
Any idea what your numbers roughly correspond to for leafs?
You have the ACI front splitter - what is in back?
Thanks.
Old 10-25-2011, 05:11 PM
Wasserott
Wasserott's Avatar
Can't remember how i calculated this but I think it was rough justice...using Spring Rate, Motion Ratio and Spring Angles
LG T1 Chg
Fr 300 176 71%
Rr 208 127 64%
What rubbed:
Front - Bottom of very expensive tray on ground
Rear - the outside of the rear tires into the fendor
ACP Parts...front nose and 72" hershy bar wing
Old 10-25-2011, 05:20 PM
John Shiels
t-1 is to soft for good aero
Old 10-25-2011, 06:26 PM
RX-Ben
RX-Ben's Avatar
Crud. Can '04 C5Z shocks accommodate the necessary spring rates?
To Do you need coil overs with a wing?
Old 10-25-2011, 07:03 PM
wallyman424
wallyman424's Avatar
don't think the stock shocks can deal with anything other than the stock spring rates.
Old 10-25-2011, 07:08 PM
RacePro Engineering
. . . . . aero devices need to be integrated into the package, and their trade-offs completely understood.
Yup! Now we are starting to see more of the puzzle unfold.
Old 10-25-2011, 08:52 PM
RX-Ben
RX-Ben's Avatar
crap, back to the drawing board. Saving aero ideas for TTS.
Quick Reply: Do you need coil overs with a wing?
