stock c5 z06 on hoosier driven hard on track leaking various fluids
test thread
test post
1) On your oil, disconnect the coupler on the throttle body and see if any oil is present. You might want to consider one of the catch cans. 2) Check the PS fluid and see if it is murky rather than clear. If so, you are going to need a new pump as the internals of yours are taking a dump. The stockers will eventually die. I replaced mine with a Turn One and flushed the system. No problems since. 3) The MC cap gasket will get hard and leak. I replaced mine with a NAPA replacemnet and no more drips.
