FS 2008 C6 Z51 Coupe Street/Track
For Sale:
2008 Atomic Orange C6 Z51 Coupe
3LT Package
16K Miles (Street, Road Course and Autocross)
Body
Venture Tape (Invisashield) Clear Bra
GM Full Length Race Spoiler
ACP World Challenge Vented Hood
APR GTC-500 Adj Wing
APR Carbon Fiber Lip
Rubber reinforce front air damn
Customized Front Air Duct
Silicon seal back rocker and quarter panel
Brakes
Speedbleeders
SRF brake fluid
Hawk Brake Pads
C5 Brake Rotors
C5 Caliper Mounts on Front
Z06 Front Brake Ducts
Quantum Spindle Duct Kit
Anti-Knock Back Spring
DRM Stainless Steel Caliper Pistons
StopTech Stainless Brake Lines
Clutch
SRF clutch fluid
Clutch Bleeder Hose
Quarter Master Optimum V 7.25" Triple Disc w GM Flex Plate
Motor
C6-Z06 Oil Cooler
Remote Oil Breather/Catch Can
ATI 10% Underdrive Superdamper P/N 917278 + Rebuild
Comp XFI CAM (222/234 .566/.576) 113 LSA
26918 Comp Cam 918 Behive Valve Spring Kit
Katech C5R IWIS Timing Chain
3 Qt Accumsump w 35/40 PSI EPS
Shim Oil Pump
Odyssey PC680 Battery and Custom Bracket
Tune
Ishihara Johnson Crank Scraper & Windage Tray
Exhaust
Stainless Works 1-7/8" Headers
Remove Catilytic Converters
Borla Stingers
Intake
Halltech Killer Bee Air Intake Filter
Vette Air Ram Air
Misc
Elite Engineering Al Heel Toe Gas Pedal
Pfadt Steering Wheel Adapter
Sparco Ring 330mm Steering Wheel
Custom Steering Column Bellows
Front & Rear Tow Hooks
Suspension
35mm Addco Front Sway Bar
LG Motorsports HD Quiet Heim End Links
Corner Weight and Allign
Heat Insulate Ball Joints
4x SKF HD Wheel Bearing/Hub BAR5049C
VBP Bushings on Control Arms
VBP Front (1048) & Rear (845) Sport Spring
Koni 3013 Single Adjustable (Yellow) Shocks
ARP Race Studs
1/8" & 3/8" Spacers
Steering Rack Travel Limiter
DRM Steering Rack Bushings
OEM Parts
Hood
Intake
Exhaust (minus mufflers)
Shocks
Steering Wheel
etc.
Price: $37,500
PM if interested
3LT Package
Body
Brakes
Speedbleeders
SRF brake fluid
Hawk Brake Pads
C5 Brake Rotors
Clutch
SRF clutch fluid
Clutch Bleeder Hose
Motor
C6-Z06 Oil Cooler
Shim Oil Pump
Tune
Exhaust
Borla Stingers
Intake
Vette Air Ram Air
Misc
Suspension
ARP Race Studs
1/8" & 3/8" Spacers
OEM Parts
Hood
Intake
Shocks
Steering Wheel
etc.
Price: $37,500
PM if interested
I had the pleasure of driving this car last year.
It is one nice ride
It is one nice ride
Wish I had some discretionary $$'s. I've watched Len baby his Pumpkin for the last three years and do PM above and beyond what I was doing after thrashing the ever loving pizz out of mine.
I miss having a street vette. The Pumpkin would make a perfect replacement.
Good luck with the sale Len although you won't need it once a prospective buyer sees the car in person and drives it.
