lt1 racers water pump q's
was doing more reserch on lt1 water pump today to improve the system
found out how the lt1 wp mixes hot and cold water via a special thermostat to avoid thermal shock...probibly another reason my colling system sucked....al the race/performance guys here said remove the thermostat an use a restrictor..its ok dont listen to anyone i know what im talking about!!! well using a restrictor eliminated the lower part of the 2 way thermostat!!! and hot engine water was gushing into the wp and getting pushed throught the engine again ans again crippleing the rads efect!!! well granted standard race v8s rarely use thermostats..i was thinking this..... if i disable the large hole in the wp where the lower seal should be hot water couldnt mix or get into the cold water port...so in effect i could have only cool crisp rad water in the motor...improve flow by eliminating turbulence of the mix and then control flow using restrictors to fine tune the system
Dumb question are you experiencing overheating at the track? If so, have you made sure your rad is clean externally from leaves and such? Is the coolant system in good condition no leaks, corrosion build up, gunk in the system, all air bleed out, proper fan operation, is the pump in good shape=impeller not corroded away to nothing, good air flow to rad aka good front splitter, etc...
Just covering the basics here...
I have never heard that before, in any case the thermostat would be fully open, so doesn't make sense to me. Just run a standard thermostat, no reason to remove.
LT1 has reverse flow cooling-(cools the heads before the engine) the biggest problem is getting air trapped in the system. If you have air, it will overheat every time. Make sure you properly bleed the system any time you mess with it there are two bleed valves, one near the thermostat and one on the heater core hose.
Does it overheat idling or with normal street driving-if so I would look at air in the system, blown head gasket, water pump. If it only overheats on the track, it may be more of a system capacity problem.
Tim
Tim
Tim
Tim
I ran the lower thermostat....I **think** it was a 160....and just cut a bigger hole in the front of the Camaro and ducted it very well....dual plane actually. Aluminum boxed. Car NEVER ran hot....had to tape up lots of the opening.
