autocross: any reason why a passenger seat is needed?
Old 10-08-2011, 05:43 PM
dizwiz24
dizwiz24's Avatar
Default autocross: any reason why a passenger seat is needed?
Im new to autocrossing and im curious if theres any reason why I would need to run a passenger seat.
This is on a heavily mod'd 93 vert w/ cage, so Im not in a stock class.
are there any weird rules out there, in autoX, that generally require a front seat?
Old 10-08-2011, 08:21 PM
acrace
acrace's Avatar
All depends what organization you're running in (NCCC, SCCA, ???) and how heavily modified it is (i.e.: what class you would be running in).
If you tell us what club/class you're looking at, I'm sure that someone can chime in with the right answer.
Old 10-09-2011, 09:19 AM
VGLNTE1
VGLNTE1's Avatar
St. Jude Donor '14-'15
to scare your passengers
Old 10-09-2011, 11:22 AM
bsalie99
bsalie99's Avatar
A pass seat is required untill you reach the prepared level class, And Prepared cars are NOT street cars, You are most likley in SSM class which requires a full interior
Old 10-10-2011, 11:41 PM
vettehardt
vettehardt's Avatar
A passanger seat and full interior is also required in NCCC for everything except RP and RPAF cars. RP and RPAF cars can have a gutted interior. Everything else is required to have a full interior.
Besides, a passenger seat helps get people interested in the sport. I try to give people rides as much as I can to try and convince people to join in the fun.
Old 10-11-2011, 12:18 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Old 10-11-2011, 01:04 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
You've had to chuck so much of the interior to get the cage in, the passenger seat is kinda moot by now isn't it?
To autocross: any reason why a passenger seat is needed?
Quick Reply: autocross: any reason why a passenger seat is needed?
