How would you load the tire trailer?
Old 08-07-2011, 07:16 PM
pit-pony
pit-pony's Avatar
Default How would you load the tire trailer?
My son and I are driving our two Corvettes a long way to a track event in Mont Tremblant, Quebec
In order to bring our 8 track wheels & tires we have a hitch on the C5 Z06 and new 4ft x 4ft trailer with 12 inch wheels and bearing buddies installed. The deck is plywood and there are no sides. I have 10 good 1.5 inch 15 foot tie down straps, each rated 1300lbs.
What would be the best way to stack and tie down these 8 wheels / tires?
I can try:
- 4 stacks of 2, laying down, they don't fit fully on the bed, as one rear stack sticks out 5 inches to the rear and one stack sticks out to the front, a bit of a diamond shape.
- tires on edge, 2 rows of 4, running side to side. Fits on deck.
- tires on edge, 2 rows of 4, running front to back. Fits on deck.
Tying all this up correctly is the key, using opposing forces front to back and side to side, but which configuration would be more secure for a long drive?
Here are two trial loads:
..jack
Old 08-07-2011, 08:39 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
the two rows of four will be best.
the four stacks of two will be worse!
When I had my small trailer I had a small truck box on the rear and put one row of four tires in front of it. As long as I got the straps tight the tires stayed on real well.
Old 08-08-2011, 09:38 AM
Solofast
Solofast's Avatar
Stacking them flat, as in the top picture will be the best. I've done both and found that the stacks in rows will tend to move around a lot more. Unless you have something on the trailer to keep them from trying to roll, like a tall chock of some kind, they will work loose. I do see that you have a lot of rachet straps, and that's a good thing, but with a row of tires four tires long, the middle ones tend to try to work their way out unless they are restrained some way.
If do them in rows, loop a strap through the four middle ones and cinch them together to make a pack of four tires, and then attach the ones on the end of that stack.
With the flat stack, you can cinch through all of the tires and tie them all together, like you apparently have done, then with four straps tie it down to the trailer and you will be fine. When I flat stack I loop a strap through the middle of the stack of four and chinch them together and then tie down the end top tires to the trailer. The real key is that middle strap that locks the stack together.
FWIW, Just my experience.
Old 08-08-2011, 09:50 AM
jaa1992
jaa1992's Avatar
St. Jude Donor '12
Its strange but when I did my tires 2/stack I had the most trouble with them bouncing and comming loose.
Maybe when I went to a row in front of the toolbox worked because the tool box was the "tall chock".
Flat works a lot better with a pole mounted to the wooden deck. Can be plastic (solid drain type piping) or iron. Make sure its got a pretty thick wall. Electrical conduit will not work.
Old 08-08-2011, 09:57 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
You have a strap at 3o'clock on that front row, you need one at 9 o'clock also.
Old 08-08-2011, 10:11 AM
pit-pony
pit-pony's Avatar
I tried the 2 rows front to back in this picture. In the picture I only have 4 straps on and plan to use the other 6 for the final tie down.
I have a wood chuck on both outside edges to help keep things tight (not nailed down yet).
It looks more solid somehow.
Old 08-08-2011, 11:25 AM
sebdavid
sebdavid's Avatar
Are you coming to the BMW Quebec Club HPDE by any chance? I'll be there instructing. Look for the guy with no track car and a WRX station wagon trailering a green Kawasaki and come and say hi if you can catch me between students!
Old 08-13-2011, 03:05 PM
pit-pony
pit-pony's Avatar
Testing the ride
Old 08-14-2011, 07:48 AM
urtoslo
urtoslo's Avatar
Is your jack on that trailer? Jack stands? Tools?
Old 08-14-2011, 04:53 PM
pit-pony
pit-pony's Avatar
It's a 4ft x 4ft bed.
With the 8 tires on the trailer ( for 2 cars at the track) there is no room for anything else. If I only load 4 tires that there would be room for a box with tools and Jack etc.
To How would you load the tire trailer?
Quick Reply: How would you load the tire trailer?
