06 Z06 wets what are you running. help
Hope some of you can help. I would like to use Hoosier wets on 10x18 front and 10x12 rear. fronts would be 275 35 18, tire diameter is 25.2 and the rears would be 305 30 18 tire diameter 25.6. would this present a problem with the ABS or other such as traction control and active handling because the difference in diameter is .4 I searched this topic for two days and came up with the need to have the difference in tire diameter anywhere from a half to one inch to avoid problems. All recomendations are appreciated. Dry I use Hoosier R6 295 30 18 and 345 30 19
