Brake backing plates
Old 08-07-2011, 11:36 AM
matteo
matteo's Avatar
Default Brake backing plates
Has anyone ever tried installing a used up and clean steel brake backing plate behind a set of worn but still good pads?
When I had my M3 it worked really well. When the front pads were down more than 50% and the rears were new, the F/R brake bias would go off and this would solve the problem. It was just a case of grinding off all the old pad material from the backing plate and sticking them behind. I could also wear the pads down a bit further before changing them. I know that stock car racing guys used to use this trick.
I've never tried it and have no idea if if it would have any advantage on a Corvette.
Old 08-08-2011, 12:31 PM
ZR1 MK
ZR1 MK's Avatar
As new pads wear and allow space, I put my titanium plates first, than the old pad backing plates. Works fine. I used to do just the backing plates till I started using the titanium too as a better heat barrier.
Old 08-08-2011, 02:31 PM
geerookie
geerookie's Avatar
Same here. Been doing it for years with the stock calipers and more recently with my Wilwood calipers.
Old 08-08-2011, 04:24 PM
sothpaw2
sothpaw2's Avatar
Did you guys have your own grinder? I don't and worry about a shop rejecting the request due to the pad compound.
Old 08-08-2011, 04:54 PM
froggy47
froggy47's Avatar
I am curious about this practice. I can see where it would lower heat transfer to the caliper. That has benefits.
I use my pads down to 2-3 mm stock calipers & have not felt any issue with f/r balance or fade or other symptoms.
The only thing I notice as pads wear down is a softer pedal at initiatiion due to (normal) pad taper.
Of course this shimming would not correct any pad taper issue.
The caliper pots are designed to extend out to adjust for pad wear.
Am I missing something else or is it mainly just the heat?
Old 08-09-2011, 02:48 AM
sperkins
sperkins's Avatar
Where did you get yours Greg? I need some for my SL4R Wilwoods.
Old 08-09-2011, 08:19 AM
geerookie
geerookie's Avatar
These are 1mm thick and the best price anywhere. When I ordered I thought I would have to grind clearance for the bridge bolt but they came cut for the bridge bolt already so the picture was not for the one sent.
http://www.speedwaymotors.com/Red-De...DisplayId=1372
Old 08-31-2011, 08:52 AM
ZR1 MK
ZR1 MK's Avatar
I use my own tools to remove pad material. Cutting wheel on portable grinder and belt sander.
Brakes perform better with pistons retracted.
I use Red Devil too for front and rear. Used fronts in rear that needed trimming. Ti is one strange material to cut.
Old 08-31-2011, 09:31 AM
waddisme
Support Corvetteforum!
waddisme's Avatar
Will those fit C5Z stock calipers or will they have to be modified? Is the $100 Hardbrakes the only other option for the shields?
Old 08-31-2011, 10:17 AM
sperkins
sperkins's Avatar
Negative. I received mine yesterday. They are only for calipers that use the 74xx pad shape.
Old 08-31-2011, 10:18 AM
sperkins
sperkins's Avatar
Isn't yours mainly an autox car?
Old 08-31-2011, 12:03 PM
froggy47
froggy47's Avatar
Correct, but doing more track lately. Getting up to speed on these techniques. For track I put some pads on that are new to 60% wear left. Use up the "thin" pads on street/autox.
I can see if you have a 100% track car you need to find ways to get all the use out of a pad.
I am not crazy about have a loose shim in the caliper as a method though.
I do think the steel pots make a lot of sense (heat wise), but wouldn't they eventually wear the (softer) bore?
Old 08-31-2011, 04:00 PM
geerookie
geerookie's Avatar
You better hope the Stainless Steel or any kind of piston are not touching the bore. They are isolated by the brakefluid and the seals are the only thing touching the bore or the piston.
The shim isn't an issue. Once my pads get to 60% - 50% I insert a 1/4" spacer plus the shim to keep the pistons further back in the bore. This helps with tapering pads, piston bind and heat isolation.
To Brake backing plates
Quick Reply: Brake backing plates
