Smartycam GPS antenna on a C6 Z06
Bought a new Smartycam on eBay (hasn't arrived from the seller yet) and was wondering what other Smartycam owners are doing for the GPS antenna...with the carbon fiber roof, the fact it is magnetized is no help. Anyone used the antenna in the trunk area? Input appreciated!
Get some of the 3m adhesive foam tape (its gray with a red release liner) and mount it at the very top center of the rear window.
That's where my Traqmate GPS antenna has been mounted without problem.
You can route the wire up under the headliner if you remove that plastic piece above the c-pillars.
