C4 Steering Column -- Help needed
Old 07-28-2011, 11:27 PM
RacePro Engineering
RacePro Engineering's Avatar
Default C4 Steering Column -- Help needed
Gentlemen,
1995 LT1 being developed for racing. Most of the non-essential electrics and electronics have been removed. We are looking for knowledgeable advice from those who have successfully removed their steering column locks.
We understand this involves disabling VATS, and we are also hoping to learn how to replace those $50 chipped keys with a simple "push-to-start" button.
Please do not simply write, "Take the column apart and take the lock out." The ignorant side of me is looking for step-by-step instructions. The more detail - the better!
Thanks,
Ed LoPresti
Old 07-28-2011, 11:36 PM
TRACKMAN2
TRACKMAN2's Avatar
Originally Posted by RacePro Engineering
Gentlemen,
Thanks,
Ed LoPresti
i just took the hole thing and chucked it ! put a staight shaft and a removeable wheel...it took a shaft, two yokes and a wheel kit.. @$100.00 works great
Old 07-29-2011, 11:30 AM
RacePro Engineering
Hello George,
I thought Valencia was in Spain. Had I known it was so close by, I would have driven down for the Formula One GP!
What you have done is exactly where we would like to end-up: no lock, no tilt, and no damn key! Would you be willing to help further with a little more elaboration? I'll start by sending you a PM, with our telephone number, and hope we can go from there.
Thanks,
Ed
Old 07-29-2011, 12:00 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Mid-America had a kit to disable the VATS
certain years you can have it programmed out of the chip
collapsible?
Old 07-29-2011, 10:35 PM
TRACKMAN2
TRACKMAN2's Avatar
collapsible?
mine isnt but u can get them looked hard at the car and if reck damage goes back far enuf to push the shaft far enuf to hit me ill have the motor in my lap anyway!!
Old 07-30-2011, 12:36 PM
John B
Pro Mechanic
John B's Avatar
Any competent auto repair shop will have the column tools to remove take it in. I loved column work get to sit down like a white collar guy.
To C4 Steering Column -- Help needed
Quick Reply: C4 Steering Column -- Help needed
