Need Help Wiring Transponder
Anyone know where in the fuse box I could make a conection for my transponder. Looking for a keyed on circut.
Car is 2007 Z06
Thanks,
G
Car is 2007 Z06
Thanks,
G
Whatever you do, don't tap into the DRL's. Ask Jason about that.
Here's a couple of breakdowns that may help. Hopefully David doesn't mind me posting his link.
http://www.davidfarmerstuff.com/c5-fuse.pdf
http://www.teamzr1.com/ubbthreads/ub...at&Number=3070
I must have stock in a relay company because I try to use a relay. Power comes from B+ and then I select any switched power, radio or ecu to turn relay on. Doing it this way does not add a load to the switched power circuit.
