Very thin wheel spacers...
Old 07-21-2011, 02:24 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
Default Very thin wheel spacers...
I just need the thinnest wheel spacers, maybe 2mm (?) for a little relief toward the center of Z wheels and SL6's. Is there such a thing?
Old 07-21-2011, 02:47 PM
Scooter70
Scooter70's Avatar
You should be able to find 1/8" (~3mm) spacers at your favorite local parts store. I ran them on my old GTO to get a little bit of breathing room between the tire and the strut.
Old 07-21-2011, 02:48 PM
JohnAlley
JohnAlley's Avatar
Doug Rippie has 1/8" spacers wokrs great on my '04 Z06 with 18" wheels on the front
JohnAlley
JohnAlley's Avatar
Doug Rippie has 1/8" spacers works great on my '04 Z06 with 18" wheels on the front
Old 07-21-2011, 03:07 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
We can build you a .020 spacer if you need it!!!
1/4, 3/8 and 5/8 are always (most of the time) in stock
Randy
Old 07-21-2011, 03:18 PM
Zenak
Terminal Vette Addict
Zenak's Avatar
i have a good set of 1/4" spacers that I will not be needing. Email me if you want them. i never used them, and they are on my shelf to be sold just been too lazy to get around to posting them.
Old 07-21-2011, 04:09 PM
SouthernSon
I have the 1/8" spacers but I get the fender rub with the 315 X 18's. The Z wheels clear without any spacers but not enough for comfort toward the center of the wheel. I am trying to split the difference between a little breathing room and getting the outside edge of the tire off the lip of the fender. The tire just barely rubs with the 1/8" ers. I guess maybe a 1/16" and just suffer what rub is there?
Old 07-21-2011, 04:17 PM
SouthernSon
My bad! They are the 1/4" now. I maybe should try the 1/8". I'll check locally first and then DRM. Appreciate the guidance.
To Very thin wheel spacers...
Quick Reply: Very thin wheel spacers...
