Looking for 05-08 Diff w/ RPO KNR Diff cooler
Old 06-13-2011, 08:08 AM
JMB92
JMB92's Avatar
Default Looking for 05-08 Diff w/ RPO KNR Diff cooler
Hi,
I am in need of a 3.42 differential for an 2005 Corvette with the external cooler mechanical pump hardware. The original part number was 24235246 and is discontinued. I think the Z06 diff from 06-08 is the replacement as far as I can tell the driveshafts are the same so the diff should be compatible, and the trans was T56 through this time as well, I am assuming a common tailshaft. The Z06 diff is PN 24238614.
I am looking for one between Detroit where I live, and Elkhart Lake, Wisconsin where I will install the part this weekend. If it's along my route I will pickup Thursday evening.
I do not really use the forums so email me at john.m.buttermore@gmail.com if you can help, or even provide more info to help my search!
Thanks,
JMB
Quick Reply: Looking for 05-08 Diff w/ RPO KNR Diff cooler
