springs?
springs?
I have done 7 track days and have 4 more in June. I am running a 2007 c6 with F55 Magnetic Selective. I have upgraded to track pads and just installed a hotchkis sway bar as I felt I was getting too much roll. I put the rear in the soft position to start can't wait to try it out on Watkins Glen.
I am toying with adding Z06 Springs. Any advise or comments to what I would gain or issure I would have? I and thinking it will keep the nose for dipping on heavy braking. Is it worth it? How dificult are they to install? Will they bolt right up? Is anyone running this combination?
Thank you for any help.
That bar will probably give you too much understeer; you're car will feel / have less grip. The Z51 springs would go nicely with those shocks. The front springs on Z51 and Z06 are almost the same up front, but the rear is softer on Z51 which is more suited to putting down the power on the 6.2. I'd do Z51 bars and springs. GM put lots of engineering into these setups...
Regarding your question about the process for changing out the springs...it isn't to hard, but it does take a little time. The only tools that I had to buy was a ball joint separator and crow feet (for torquing the ball joints). The Pfadt website has good instructions, under coil over installation, that cover the spring removal. Basically you need to separate the ball joint and remove the upper suspension and a shock on one side...then, you can remove the spring. After everything is reassembled you need to have the car realigned.
I recently changed my Z-51 springs and shocks to Z06 (I already had Z06 sway bars) and I am happy with the difference. Much less body roll and less pitching under acceleration and braking. I also have Z06 body panels, wheels and tires...so I don't know how they would be with stock sized tires.
If you carefully mark the eccentric adjusters on the pivot bolts, you can reassemble without needing to realign...won't be perfect, but very close.
That is true as long as you get the ride height set exactly the same as it was before. If you change ride height, you changed camber and toe.
