Best way to tie down Z06, not using the frame holes
Old 06-07-2011, 08:12 PM
bsalie99
bsalie99's Avatar
Default Best way to tie down Z06, not using the frame holes
I am picking up a rollback trailer this weekend for my 2002 Z06. What is the best way to tie it down on the trailer, Without using the factory frame holes. I have rocker rails/jacking plates that are perm on the car and they cover the factory holes. Also my race wheels are CCW clasic race wheels, so I dont think a strap thru the wheel will work.
Any Ideas?
thanks
Old 06-07-2011, 08:17 PM
TheKomoman
Support Corvetteforum!
TheKomoman's Avatar
St Jude Donor '13
Originally Posted by bsalie99
I am picking up a rollback trailer this weekend for my 2002 Z06. What is the best way to tie it down on the trailer, Without using the factory frame holes. I have rocker rails/jacking plates that are perm on the car and they cover the factory holes. Also my reace wheels are CCW clasic race wheels, so I dont think a strap thru the wheel will work.
Any Ideas?
thanks
Wheel nets seem like the last option there.
Old 06-07-2011, 08:56 PM
Joe_Planet
Joe_Planet's Avatar
when i trailered my honda s2000 i just put straps through the lower control arms and tie down to d rings in the floor. car didnt go anywhere and wasnt damaged.
i would think the same can be applied to the vette.
Old 06-07-2011, 09:27 PM
vettehardt
vettehardt's Avatar
With my brother's 04 Z06 and my dad's 90 ZR-1, we use an axle strap around the lower control arm on the front. We cross the tie downs also. On the rear, we use an axle strap through the wheels but do not cross the tie downs.
Old 06-07-2011, 10:21 PM
CP Thunder
CP Thunder's Avatar
I use straps through our CCWs with no problem in the front and don't cross them (puts strain on the steering rack. I cross the rears but put the straps through the lower control arms on the outside of the sway bar endlink........works like a charm. That way you don't get the strap wedged in the suspension bushing area when the car bounces around a bit in the trailer..............
Old 06-07-2011, 10:27 PM
mphox
mphox's Avatar
I use 4 straps one over each tire with two d rings and one square ring.
Like this
http://www.macscustomtiedowns.com/product/214/WheelNets
Except I use a strap not a tire net
Old 06-08-2011, 12:04 AM
dvandentop
dvandentop's Avatar
straps through the wheels, no issues here towed many miles
Old 06-08-2011, 08:47 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
I loop the strap over the lower A arms. Never a problem!
Old 06-08-2011, 08:59 AM
sabastian458
sabastian458's Avatar
Good info, I was going to make the same thread today as I need to haul my Z06 this weekend for the first time.
Old 06-08-2011, 09:00 AM
SinisterC6
SinisterC6's Avatar
This. Have the straps criss cross to prevent any possible movement. That is tie the strap from left lower control arms to right side of trailer:
http://www.youtube.com/watch?v=DG65mcICyuY
Old 06-08-2011, 03:42 PM
JimbeauZ06
JimbeauZ06's Avatar
My advice is get rid of the jack pucks and use the slots in the frame rails. All straps should be crossed from side to side to evenly distribute the load on the straps and insure lateral stability. (this last fact was beat into us repeatedly when I was in the Army)
Remember you're not just tying the car down to keep on the trailer while you drive to the track, you're also securing it to the trailer to prevent it from becoming a 3000lb projectile in event of a (heaven forbid) collison. Sounds dramatic I know, but look how much money we spend on helmets, Hans, seats, fire suppression, titanium lugnuts , and other safety gear that we hope never to have to "use".
I know. Say it with me: "I've always done it this way and never had an issue." Yep and when I was young I drove without seatbelts and rode my motorcyle without a helmet and never had an issue either. Wasn't my brightest moment though.
Just food for thought.
Old 06-08-2011, 04:05 PM
SouthernSon
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
A way with words!
To Best way to tie down Z06, not using the frame holes
Quick Reply: Best way to tie down Z06, not using the frame holes
