C6 brake sensor
C6 brake sensor
Installing a brake pressure sensor for a data logger. The supplier suggested to tap the master cylinder at the front as shown below left. There are some posts here on running a tee. Which side and what about pressure variance? C6 MC on the right
Interesting. I would be a little worried whether there is enough material in the front to form a good seal. Notice how there is a bit of extra casting around the ports.
For a tee, pick either. On the C5, the port closest to the firewall is a very rare M12 x 1.5 fitting. If the MC on the C6 is the same, use the front port as a tee will be much easier to find. All the proportioning is done by the abs unit, so both MC ports will see the same pressure (unless there is a problem).
Jim
http://forums.corvetteforum.com/c5-t...ring-help.html
