Braided steel brake lines = firmer pedal?
Old 05-31-2011, 06:42 PM
torque*is*cheap
torque*is*cheap's Avatar
Default Braided steel brake lines = firmer pedal?
Just thought I'd poll people who have done this modification. I've got the stock Z51 braking system (2005 C6), and the pedal is a bit squishy even after repeated bleedings. Any noticeable improvement after swapping the lines out??
Old 05-31-2011, 06:50 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
not really.
Old 05-31-2011, 06:57 PM
wtknght1
wtknght1's Avatar
For just normal street driving, not really, but I noticed quite a bit of difference when I got on track and started pounding on the brakes lap after lap. The other big improvement was switching to Castrol SRF. Do those two things, pump some air to the brakes and you'll have a good pedal!
Old 05-31-2011, 07:06 PM
mountainbiker2
mountainbiker2's Avatar
Originally Posted by John Shiels
not really.
That's my thought. Autocross car.
Old 05-31-2011, 07:27 PM
torque*is*cheap
And occasional track day!
Old 05-31-2011, 09:58 PM
John Shiels
spend money on SRF first.
Old 05-31-2011, 11:44 PM
StKnoWhere
StKnoWhere's Avatar
After fresh fluid and a proper bleed, the pedal should not be squishy.
How are you bleeding the system?
Old 06-01-2011, 01:19 AM
Zenak
Terminal Vette Addict
Support Corvetteforum!
Zenak's Avatar
http://forums.corvetteforum.com/auto...e-learned.html.
Read and learn young grasshopper
Old 06-01-2011, 02:09 AM
2000BSME
2000BSME's Avatar
Originally Posted by Zenak
I think people might take you more seriously if your sn didn't sound so much like "sleestak"
J/k.
Old 06-01-2011, 04:35 PM
John Shiels
J/k.
what is a sleestak?
Old 06-01-2011, 06:36 PM
davidfarmer
davidfarmer's Avatar
I can't tell a difference....you have to "feel" the pedal wherever it goes (even if it's to the floor). SS lines require constant monitoring and careful installation!
Old 06-01-2011, 08:42 PM
Gray Ghost GS
"AlohaC5" Senior Member
Gray Ghost GS's Avatar
what is a sleestak?
I haven't heard that name since the 70s LOL!
Old 06-02-2011, 12:10 AM
longdaddy
longdaddy's Avatar
if changing lines to steel makes the pedal "firmer", somethng was seriously wrong with the old lines.
mostly safety thing - if road debris or your wheel/suspension comes in contact with the brake line, you do not want it to be the weakest link
Old 06-02-2011, 12:21 AM
froggy47
froggy47's Avatar
This is an "overrated" upgrade, nevertheless many will continue to do it & rave about how great the brakes are now.
Old 06-02-2011, 03:58 AM
l8_apexer
l8_apexer's Avatar
Respectfully disagree.
HAving been with students in Corvettes is which the rubber brake lines have failed-- it is relatively inexpensive peace of mind. Had one with a relatively new C6 that the line would expand with a bubble under hard braking. Quite frightful-- riding as the instructor I could feel it in the car under hard braking.
It was the first upgrade, along with Z06 brake ducts I did to my car. Yes there needs to be proper fluid for track driving, proper pads, and bleed the system every event (or each track day).
I definitely notice a firmer pedal, and it holds. Not as firm and condifence inspriring as what I had in my 911 (put stainless steel lines in it too).
Please note that if you do put in braided steel lines-- they need regular attention and maintenance-- and replacement periodically.
Old 06-02-2011, 12:42 PM
torque*is*cheap
I've done several sets of these lines on several cars over the years, with varying results, and I know all about routing them carefully, etc., as they don't always follow the same contours as the stock lines, and interference with tires/suspension is always a possibility.
My experience is that the pedal-feel gain is slight, if at all, but I know firsthand that improvement is possible, depending on the car. To me, a slight improvement would be worth a set of lines.
Old 06-02-2011, 01:19 PM
Aardwolf
Aardwolf's Avatar
Here is an easy test, grab the brake line and have someone press the brake pedal. The amount the C4 lines swelled was significant.
To Braided steel brake lines = firmer pedal?
Old 06-02-2011, 04:41 PM
John Shiels
I think I'll try my brake lines on my truck tomorrow with a caliper. I think if the material was expanding enough so you can feel it in your hand it probably would not stop expanding and burst. Then again a garden hose expands but it is probably not near the pressure of a brake line. Someone get out the calipers.
http://www.stoptech.com/tech_info/wp...teel_Q&A.shtml
Old 06-02-2011, 10:05 PM
froggy47
froggy47's Avatar
Alone the lines of this thread, are there any heavy duty aftermarket non steel lines for Vettes? I am not a fan of the steel covered lines, but I have no problem with an upgrade.
What goes on the ZR1?
Old 06-02-2011, 10:10 PM
Gray Ghost GS
I use Goodridge SS brake lines on all my performance cars - more for safety reasons than performance.
Quick Reply: Braided steel brake lines = firmer pedal?
